Topic: Uno R3 ATMega328P avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp= (Read 2254 times) previous topic - next topic
samjamie0104
Dnox
liuzengqiang
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
liuzengqiang
It is a Chinese clone
Still waiting for your answer. What VID and PID? I posted my troubleshooting blog post and you said you did it. So if you did do it, what are the VID and PID numbers you got out of it?
Maarten_pa0mhe
Hello,
I have same problem with CH340 board. ( avrdude: stk500_getsync() attempt 10 of 10: not in sync: )
Normal communication is working OK: so Arduino Serial monitor works.
The board Uno:
VID: 1A86
PID: 7523
Driver USB-SERIAL CH340 version 3.3.2011.11
OS: windows 7 64 bit
Nothing connected to the board.
Tried it with several new boards.
Hope you can HELP.
Best regards Maarten
TARS
Ok, since the site is completely in chinese, I am very hesitant to download.
I hadn't touched my UNO in a few months, been mainly playing with nano's.   Went to upload some code the other day, got a similar error  (avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x07).   Shortly after, my nano's stopped uploading (win7).  Went and upgraded to 1.6.5 IDE, and it fixed the nano issue.
Still getting the same error on the Uno though.   It's recognized as an Uno on Com5 (it's always been on com5), the power light is on, and led on 13 is on.   When uploading, every 10 seconds or so the Rx light blinks once.
All code, including the blink example, no wires attached, has the same result.  I have tried other 328's on the board too, as I was planning to use the Uno to program some chips.   Any suggestions?
Don't worry,
the installation process is in english
