Help whit Menu
Hi.
First a wanna start be saying that im a newbe at this so sorry if im stuped:)
I got some help whit this code, but the menusystem i try to make my self,as you all can see:)
But now i have run in to a problem i can fix:(
Im gonna try to explane the problem:
When i start the code, the first text on the lcd shows up = working
Then i can hit "A" or "B" on the keypad to get to diffrent menus = working
In menu "A" i can enter numbers and everything works good.
When i press "B" i get in to that menu BUT i cant enter any numbers, if i hit any key the menu goes back to menu"A"???
How can i get menu "B" to work the same way as menu "A"?
Thanks for any help!
#include <AccelStepper.h>
#include <Keypad.h>
#include <LiquidCrystalFast.h>
LiquidCrystalFast lcd(12, 10, 11, 5, 4, 3, 2);
volatile int aPos=0;
volatile int bPos=0;
volatile int currPos=0;
volatile int aCur=0;
volatile int bCur=0;
int val = 0;
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {22, 24, 26, 28};
byte colPins[COLS] = {31, 33, 35, 37};
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );  // Keypad Library definition
#define backlight_pin A2
AccelStepper stepperA(1, A0, A1);
AccelStepper stepperB(2, A3, A4);
  lcd.begin(20, 4);
  lcd.setCursor(0,0);
  lcd.print( "->PALLINSTELLNING<-" );
  lcd.setCursor(0,2);
  lcd.print("A = LENGD");
  lcd.setCursor(11,2);
  lcd.print("B = BREDD");
  analogWrite(backlight_pin, 250);
  stepperA.setMaxSpeed(1500);
  stepperA.setAcceleration(400);
  stepperB.setMaxSpeed(1500);
  stepperB.setAcceleration(400);
void loop(){
  pinMode(6, OUTPUT);
  analogWrite(6, 140);
  char keypressed = keypad.getKey();
  if (keypressed != NO_KEY){
  switch (keypressed) {
    case '1':
    case '2':
    case '3':
    case '4':
    case '5':
    case '6':
    case '7':
    case '8':
    case '9':
    case '0':
    setPos( keypressed );
     break;
    case 'A':
      menylengd();
      break;
    case 'B':
      menybred();
      break;
    case '*':
      deletenumber();
       break;
    case '#':
      calculatedistance();
      break;
    case 'C':
      currPos=0;
      break;
    case 'D':
      currPos=1;
      break;
void setPos( char num ) {
  int iNum = String(num).toInt();
  switch( currPos ) {
  case 0:
   if( aPos>999) return;
    aPos*=10;
    aPos+=iNum;
    break;
    case 1:
    bPos*=10;
    bPos+=iNum;
    break;
   Lcdlengd();
void deletenumber() {
  switch( currPos ) {
    case 0:
      aPos/=10;
      break;
    case 1:
      bPos/=10;
      break;
 Lcdlengd();
void menylengd() {
  switch( currPos ) {
  case 0:
  break;
Lcdlengd();
void menybred() {
  switch( currPos ) {
  case 0:
  break;
Lcdbredd();
void calculatedistance() {  // Used to create a full number from entered numbers
  if( aPos != aCur ) {
    moveStepper( 0 );
  if( bPos != bCur ) {
    moveStepper( 1 );
Lcdlengd();
void moveStepper( int which ) {
  lcd.begin( 20,4 );
  lcd.setCursor( 0,1 );
  lcd.print( "->FLYTTAR FOTOCELL<-" );
  lcd.print(" ");
  long calculatedmove;
  switch( which ) {
    case 0:
      calculatedmove = (aPos * 1938UL)/20;
      stepperA.runToNewPosition( calculatedmove );
      aCur = aPos;
      break;
    case 1:
      calculatedmove = (bPos * 1938UL)/20;
      stepperB.runToNewPosition( calculatedmove );
      bCur = bPos;
      break;
Lcdlengd();
void Lcdbredd() {
  String strA = String(bPos)+ "mm";
  String strB = String(bCur)+ "mm";
  String strC = "----->BREDD<------";
  lcd.begin(20, 4);
  lcd.setCursor(0,0);
  lcd.print(strC);
  lcd.setCursor(0,2);
  lcd.print(aPos);
  lcd.setCursor(0,2);
  lcd.print(strA);
  lcd.setCursor(0,1);
  lcd.print("ANGE:");
  lcd.setCursor(14,2);
  lcd.print(strB);
  lcd.setCursor(8,1);
  lcd.print("AKTUELL POS:");
 void Lcdlengd() {
  String strA = String(aPos)+ "mm";
  String strB = String(aCur)+ "mm";
  String strC = "----->LENGD<------";
  lcd.begin(20, 4);
  lcd.setCursor(0,0);
  lcd.print(strC);
  lcd.setCursor(0,2);
  lcd.print(aPos);
  lcd.setCursor(0,2);
  lcd.print(strA);
  lcd.setCursor(0,1);
  lcd.print("ANGE:");
  lcd.print(strB);
  lcd.setCursor(8,1);
You are calling Lcdlengd() from void setPos().
You could add a variable that keep track of which menu you are in at the moment.
thanks for the reply,
I dont realy know how to do that:(
Can i call both display from void setPos().?
Something like this, you have to declare menuVal yourself
    case 'A':
      menuVal=1;
      menylengd();
      break;
    case 'B':
      menuVal=2;
      menybred();
      break;
  switch( currPos ) {
  case 0:
    aPos*=10;
    aPos+=iNum;
    break;
    case 1:
    bPos*=10;
    bPos+=iNum;
    break;
if (menuVal==1){
   Lcdlengd();
else if (menuVal==2){
  Lcdbredd();
Thanks for the input Gabriel, but i still can get it to work:(
Is this how you meen it to be?
#include <Keypad.h>
volatile int menuVal=1;
volatile int menuVal=2;
int val = 0;
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
  lcd.begin(20, 4);
  lcd.setCursor(0,0);
  lcd.setCursor(0,2);
void loop(){
  pinMode(6, OUTPUT);
    case '1':
    case '2':
    case '3':
    case '4':
    case '5':
    case '6':
    case '7':
    case '8':
    case '9':
    case '0':
     break;
    case 'A':
      menuVal=1;
      menylengd();
      break;
    case 'B':
      menuVal=2;
      menybredd();
      break;
    case '*':
      deletenumber();
       break;
    case '#':
      break;
    case 'C':
      currPos=0;
      break;
    case 'D':
      currPos=1;
      break;
  switch( currPos ) {
  case 0:
    aPos*=10;
    aPos+=iNum;
    break;
    case 1:
    bPos*=10;
    bPos+=iNum;
    break;
if (menuVal=1){
   Lcdlengd();
else if (menuVal=2){
  Lcdbredd();
   Lcdlengd();
  switch( currPos ) {
    case 0:
      aPos/=10;
      break;
    case 1:
      bPos/=10;
      break;
 Lcdlengd();
void menylengd() {
  switch( currPos ) {
  case 0:
  break;
Lcdlengd();
void menybredd() {
  switch( currPos ) {
  case 0:
  break;
Lcdbredd();
    moveStepper( 0 );
    moveStepper( 1 );
Lcdlengd();
  lcd.begin( 20,4 );
  lcd.print(" ");
  switch( which ) {
    case 0:
      aCur = aPos;
      break;
    case 1:
      bCur = bPos;
      break;
Lcdlengd();
void Lcdbredd() {
  lcd.begin(20, 4);
  lcd.setCursor(0,0);
  lcd.print(strC);
  lcd.setCursor(0,2);
  lcd.print(aPos);
  lcd.setCursor(0,2);
  lcd.print(strA);
  lcd.setCursor(0,1);
  lcd.print("ANGE:");
  lcd.print(strB);
  lcd.setCursor(8,1);
 void Lcdlengd() {
  lcd.begin(20, 4);
  lcd.setCursor(0,0);
  lcd.print(strC);
  lcd.setCursor(0,2);
  lcd.print(aPos);
  lcd.setCursor(0,2);
  lcd.print(strA);
  lcd.setCursor(0,1);
  lcd.print("ANGE:");
  lcd.print(strB);
  lcd.setCursor(8,1);
Just to able able to highlight in your code...
You forgot it should be == in if statements, and remove original call to Lcdlengd
Trigger80:
if (menuVal=**=1){
Lcdlengd();
else if (menuVal=
=**2){
Lcdbredd();
~~ Lcdlengd();~~
Thanks for all the help Gabriel.
If i use "volatile int menuVal=2;, i get an error message:
redefinition of 'volatile int menuVal'
If i use "volatile int menuVall=2 no error message
But if im in "B" menu and hit a key, i goes back and enters the number in "A" menu...?:frowning:
#include <Keypad.h>
volatile  int menuVall=2;
int val = 0;
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
  lcd.begin(20, 4);
  lcd.setCursor(0,0);
  lcd.setCursor(0,2);
void loop(){
  pinMode(6, OUTPUT);
    case '1':
    case '2':
    case '3':
    case '4':
    case '5':
    case '6':
    case '7':
    case '8':
    case '9':
    case '0':
     break;
    case 'A':
      menuVal=1;
      menylengd();
      break;
    case 'B':
      menuVall=2;
      menybredd();
      break;
    case '*':
      deletenumber();
       break;
    case '#':
      break;
    case 'C':
      currPos=0;
      break;
    case 'D':
      currPos=1;
      break;
  switch( currPos ) {
  case 0:
    aPos*=10;
    aPos+=iNum;
    break;
    case 1:
    bPos*=10;
    bPos+=iNum;
    break;
if (menuVal==1){
   Lcdlengd();
else if (menuVall==1){
  Lcdbredd();
  switch( currPos ) {
    case 0:
      aPos/=10;
      break;
    case 1:
      bPos/=10;
      break;
 Lcdlengd();
void menylengd() {
  switch( currPos ) {
  case 0:
  break;
Lcdlengd();
void menybredd() {
  switch( currPos ) {
  case 0:
  break;
Lcdbredd();
    moveStepper( 0 );
    moveStepper( 1 );
Lcdlengd();
  lcd.begin( 20,4 );
  lcd.print(" ");
  switch( which ) {
    case 0:
      aCur = aPos;
      break;
    case 1:
      bCur = bPos;
      break;
Lcdlengd();
void Lcdbredd() {
  lcd.begin(20, 4);
  lcd.setCursor(0,0);
  lcd.print(strC);
  lcd.setCursor(0,2);
  lcd.print(aPos);
  lcd.setCursor(0,2);
  lcd.print(strA);
  lcd.setCursor(0,1);
  lcd.print("ANGE:");
  lcd.print(strB);
  lcd.setCursor(8,1);
 void Lcdlengd() {
  lcd.begin(20, 4);
  lcd.setCursor(0,0);
  lcd.print(strC);
  lcd.setCursor(0,2);
  lcd.print(aPos);
  lcd.setCursor(0,2);
  lcd.print(strA);
  lcd.setCursor(0,1);
  lcd.print("ANGE:");
  lcd.print(strB);
  lcd.setCursor(8,1);
   [code]
[/code]
#include <Keypad.h>
int menuVal;
int val = 0;
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
  lcd.begin(20, 4);
  lcd.setCursor(0,0);
  lcd.setCursor(0,2);
void loop(){
  pinMode(6, OUTPUT);
    case '1':
    case '2':
    case '3':
    case '4':
    case '5':
    case '6':
    case '7':
    case '8':
    case '9':
    case '0':
     break;
    case 'A':
      menuVal=1;
      menylengd();
      break;
    case 'B':
      menuVal=2;
      menybredd();
      break;
    case '*':
      deletenumber();
       break;
    case '#':
      break;
    case 'C':
      currPos=0;
      break;
    case 'D':
      currPos=1;
      break;
  switch( currPos ) {
  case 0:
    aPos*=10;
    aPos+=iNum;
    break;
    case 1:
    bPos*=10;
    bPos+=iNum;
    break;
if (menuVal==1){
   Lcdlengd();
  Lcdbredd();
  switch( currPos ) {
    case 0:
      aPos/=10;
      break;
    case 1:
      bPos/=10;
      break;
 Lcdlengd();
void menylengd() {
  switch( currPos ) {
  case 0:
  break;
Lcdlengd();
void menybredd() {
  switch( currPos ) {
  case 0:
  break;
Lcdbredd();
    moveStepper( 0 );
    moveStepper( 1 );
Lcdlengd();
  lcd.begin( 20,4 );
  lcd.print(" ");
  switch( which ) {
    case 0:
      aCur = aPos;
      break;
    case 1:
      bCur = bPos;
      break;
Lcdlengd();
void Lcdbredd() {
  lcd.begin(20, 4);
  lcd.setCursor(0,0);
  lcd.print(strC);
  lcd.setCursor(0,2);
  lcd.print(aPos);
  lcd.setCursor(0,2);
  lcd.print(strA);
  lcd.setCursor(0,1);
  lcd.print("ANGE:");
  lcd.print(strB);
  lcd.setCursor(8,1);
 void Lcdlengd() {
  lcd.begin(20, 4);
  lcd.setCursor(0,0);
  lcd.print(strC);
  lcd.setCursor(0,2);
  lcd.print(aPos);
  lcd.setCursor(0,2);
  lcd.print(strA);
  lcd.setCursor(0,1);
  lcd.print("ANGE:");
  lcd.print(strB);
  lcd.setCursor(8,1);
now if i add a number in menu"B" i cant see the first number it does not show over the "0" if i enter 1234, it looks like this: 0234...
And when i go back to "A" menu its been enter there to, "A" menu = 1234 "B" menu 0234....
Strange...
i switch the "aPos" and "bPos" then the "b" menu work but not the "A" menu, so its looks like there is a problem here in this part?
It always enter in both menu at the same time...
  switch( currPos ) {
  case 0:
    bPos*=10;
    bPos+=iNum;
    break;
    case 1:
   if( bPos>999) return;
    aPos*=10;
    aPos+=iNum;
    break;
  }[code]
[/code]
