Speed up arduino
int A,B,C ;
int fsrPin = 0;     // the FSR and 10K pulldown are connected to a0
int fsrReading;     // the analog reading from the FSR resistor divider
int fsrVoltage;     // the analog reading converted to voltage
unsigned long fsrResistance;  // The voltage converted to resistance, can be very big so make "long"
unsigned long fsrConductance;
long fsrForce;       // Finally, the resistance converted to force
int count = 0;      //count of position
double Force_corr, Pos_corr;
int Status_out, enable, Regler_Start, Init_Start, corr_Start, Auto_Status;
int Enable;        //emergency stop
double SettingValue, PosGain;
double x, Sampletime,v, w;
double SatForce;
int V1;
double Freq;
double clock;
int state = HIGH;
  Status_out = enable = Regler_Start = Init_Start = corr_Start = Auto_Status = 0 ;
  Enable = 1;
  attachInterrupt(4, emergency, RISING);   //interupt 4 , digital pin 19
   state = HIGH;
// analogRead(1);
 digitalWrite (10, state);
  Position_Count();
  Force();
  Flow_Control(2);
  Correction(fsrForce, count, corr_Start);
  if (Regler_Start == 0)
    int f = 0-10*25;
    Pos_SetValue(353.81,3.8095,22.8571);
    Force_SetValue(f);
    Potential();
    Virtual_System(0.099048,0.2,0,-0.04,150);
   state =!state;
void Position_Count()
  int p=0;
  int a1 = 0;
  int b1 = 0;
  A = digitalRead(22);
  B = digitalRead(24);
  if(A==1 && a1!=A)
     if(B==1)
       p=p-1;
       a1=1;
       b1=1;
     count=p;
   if(A==1 && a1!=A)
      if(B==0)
        p=p+1;
        a1=1;
        b1=0;
      count=p;
   if(A==0 && a1!=A)
      if(B==1)
        p=p+1;
        a1=0;
        b1=1;
      count=p;
   if(A==0 && a1!=A)
      if(B==0)
        p=p-1;
        a1=0;
        b1=0;
      count=p;
   if(B==1 && b1!=B)
      if(A==1)
        p=p+1;
        b1=1;
        a1=1;
      count=p;
   if(B==1 && b1!=B)
      if(A==0)
        p=p-1;
        b1=1;
        a1=0;
      count=p;
   if(B==0 && b1!=B)
      if(A==1)
        p=p-1;
        b1=0;
        a1=1;
      count=p;
   if(B==0 && b1!=B)
      if(A==0)
        p=p+1;
        b1=0;
        a1=0;
      count=p;
void Force()
   fsrReading = analogRead(fsrPin);
  // analog voltage reading ranges from about 0 to 1023 which maps to 0V to 5V (= 5000mV)
//  fsrVoltage = map(fsrReading, 0, 1023, 0, 5000);
  fsrVoltage = fsrReading*5;
    // The voltage = Vcc * R / (R + FSR) where R = 10K and Vcc = 5V
    // so FSR = ((Vcc - V) * R) / V        yay math!
    fsrResistance = 5000 - fsrVoltage;     // fsrVoltage is in millivolts so 5V = 5000mV
    fsrResistance *= 10000;                // 10K resistor
    fsrResistance /= fsrVoltage;
    fsrConductance = 1000000;           // we measure in micromhos so
    fsrConductance /= fsrResistance;
    // Use the two FSR guide graphs to approximate the force
    if (fsrConductance <= 100)                  //range 0-2N
      fsrForce = fsrConductance /20;
//      Serial.print("Force in Newtons: ");
//      Serial.println(fsrForce);
      fsrForce = fsrConductance /50;                //range 80N-100N
//      fsrForce /= 50;
  fsrForce = fsrForce*3;
void Force2()
   fsrReading = analogRead(1);
//      fsrForce /= 50;
void Correction(double Force, double Position, int Reset)
  int mtime = 0;
  int force = 0;
  int pos = 0;
  int mreset = 0;
  if(Reset==1 && mreset==0)
    if(mtime==0)
        mtime = clock;
    if(mtime >= 0)
        if(clock>(mtime + 5))
            force = Force;
            pos = Position;
            mreset = 1;
  if(Reset==0)
    mreset=0;
    mtime=0;
  Force_corr = force;
  Pos_corr = pos;
void Flow_Control(int Status)
 // int Status_out, enable, Regler_Start, Init_Start, corr_Start, Auto_Status;
//   Status_out = enable = Regler_Start = Init_Start = corr_Start = Auto_Status = 0;
  Status_out=Status;    //Status = input,   Status_out = output
  if(Enable==1)         //Enable = input,   enable = output
    if(Status==0)
        enable=0;
    if(Status==1)
        enable=4.5;
        Init_Start = 1;
        Init_Start = 0;
    if(Status==2)
        enable=0;
        corr_Start=1;
        corr_Start=0;
    if(Status==3)
        enable=4.5;
        Regler_Start=1;
        Regler_Start=0;
  if(Enable==0)
    enable==0;
    Regler_Start=0;
    corr_Start=0;
    Auto_Status=0;
void emergency()
  Enable = 0;
// Pos_SetValue(353.81, 3.8095, 22.8571 )
void Pos_SetValue(double P_Person, double I_Gain, double D_Gain)
  double istPosition ;
  double SetValue;
  double PosDiff;
  int Position;
  Position = count - Pos_corr;
  istPosition = Position *0.007;
  PosDiff = x - Position;
  double intPosDiff;
  //intPosDiff ---> integration of PosDiff
  intPosDiff += PosDiff*Sampletime;
  SetValue = v*w*D_Gain + PosDiff*P_Person +I_Gain*intPosDiff;
  // SettingValue ---> go through saturation function
  if(SetValue >= 10)
    SettingValue = 10;
  else if(SetValue <= -10)
    SettingValue = -10;
    SettingValue = SetValue;   // Output Setting Value to control motor
  PosGain = SetValue - SettingValue;
/////////  Force_SetValue( -10*25 / -5*15, )
void Force_SetValue(int Ks)
  int Force;
  double SetForce;
  Force = fsrForce - Force_corr;
  SetForce = x*Ks -23*Force;
  // SatForce --> SetForce go through saturation
  if(SetForce >= 50)
    SatForce = 50;
  else if(SetForce <= -50)
    SatForce = -50;
    SatForce = SetForce;   // Output Setting Value to control motor
/////////////////// Virtual_System(0.099048, 0.2, ??, -0.04, 150)
void Virtual_System(double maxampl, double SollAmpl, double Kp, double Damp, int Mass )
  double Amplitude, P_ampl;
  double Sum;
  double dampingValue, Damping;
  double Vset;
  double acceleration, acceleration2;
  Amplitude = sqrt(v*v + x*x);
  // C code for dampingValue, if...else
  if(Amplitude >= maxampl && Amplitude <= maxampl+0.05)
    dampingValue = 0.1*Vset;
  else if(Amplitude > maxampl+0.05)
    dampingValue = 0.3*Vset;
  else if(Amplitude > maxampl+0.1)
    dampingValue = 10*Vset;
    dampingValue = 0;
  P_ampl = Amplitude - SollAmpl;
  Damping = P_ampl*Kp;
  Sum = Vset*Damping;
  acceleration = 0 - dampingValue - Sum - Vset*Damp - x*w - SatForce/Mass;
  double V_Conversion;
  if(v >= 0)
   V_Conversion = 1 / ((1+V1)*(1+V1)) ;
    V_Conversion = 1 / ((1-V1)*(1-V1)) ;
  acceleration2 = acceleration*V_Conversion;
  // v = integrate of acceleration2
  v = v + acceleration2;
  Potential();
  w = Freq * 2*PI/60 ;
   Vset = v*w - PosGain;
  //x = integrate of Vset
  x = x + Vset*Sampletime ;
void Potential()
  int PotentioPin = 2;
  int PotentioReading;
  int Potentiometer;
  PotentioReading = analogRead(PotentioPin);
  // Potentiometer reading ranges from about 0 to 1023 which maps to 0V to 5V (= 5000mV)
//  Potentiometer = map(PotentioReading, 0, 934, -2500, 2500);
  Potentiometer = PotentioReading * 5;
  double U;
  U = Potentiometer;
  if (PotentioReading != 0 )
      Freq = floor((8+3*U)*4+0.5)/4;
      Freq = 1;
