Replacing Processing internally within Arduino
I currently have a working model which displays data from a webpage on a LED matrix, this uses an Arduino Mega connected to an LED Matrix and a computer, via Serial Processing on the computer gets the data online then sends to the arduino which displays it on the LED matrix.
This works great.
However my next mission is to get it to be self contained, I am able to get the data from the webpage using just the arduino (with wifi shield) and display it on the Matrix, however when I try to get the data online again it breaks the matrix.
I am looking for any other ways to get a very small amount of data from a webpage than the one I am using which is defiantly not working. See below for my code:
 *Light Plinth
 Circuit additions:
 * WiFi shield
 * AdaFruit 32x32 LED Matrix
 Created 20 Feb 2013
 By Chris Evans; Wonder Room
// LED Matrix Libraries.
#include <Adafruit_GFX.h>   // Core graphics library
#include <RGBmatrixPanel.h> // Hardware-specific library
// Wifi Library
#include <WiFi.h>
#include <SPI.h>
// Matrix Pin Layout:
//#define CLK 10
//#define OE  11
//#define LAT 12
#define CLK 10
#define OE  11
#define LAT 12
#define A   A8
#define B   A9
#define C   A10
#define D   A11
RGBmatrixPanel matrix(A, B, C, D, CLK, LAT, OE, false);
//Variable Set Up:
String pageValue;
String tempValue;
int num1 = 3;
//Wifi Set up //////////////////////////////////////////////////////////
      /* Home Set Up:
      char ssid[] = "_";     //  your network SSID (name)
      char pass[] = "thisistheshit";  // your network password
char ssid[] = "3MobileWiFi-3c77";     //  your network SSID (name)
char pass[] = "01269109";  // your network password
int status = WL_IDLE_STATUS;     // the Wifi radio's status
WiFiClient client;
// Configure Website Reading ///////////////////////////////////////////
char inString[32]; // string for incoming serial data
int stringPos = 0; // string index counter
boolean startRead = false; // is reading?
byte server[] = {
  173,254,28,46 }; //ip Address of the server you will connect to
//The location to go to on the server
//make sure to keep HTTP/1.0 at the end, this is telling it what type of file it is
String weblocal = "/~evansch1/arduinoadmin/fbconn.php?uid=wonderroomarduino HTTP/1.0"; // Arduinos Unique ID Goes here!
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue:
    while(true);
  // attempt to connect to Wifi network:
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  Serial.print("You're connected to the network");
  tempValue = connectAndRead();
  Serial.println("tempValue = " + tempValue);
  matrix.begin();
  loading();
   matrix.fillScreen(matrix.Color333(0, 0, 0));
   matrix.setCursor(7, 4);    // start in the middle
   matrix.setTextSize(1);     // size 1 == 8 pixels high
   matrix.setTextWrap(true);
   matrix.setTextColor(matrix.Color333(7,7,7));
   matrix.println(tempValue);
   drawHand();
   delay(10000);
// Get Data From FB //////////////////////////////////////////////////////
String connectAndRead(){
  //connect to the server
  Serial.println("reading page...");
  //port 80 is typical of a www page
  if (client.connect(server, 80)) {
    Serial.println("page found.");
    client.print("GET ");
    client.println(weblocal);
    client.println();
    //Connected - Read the page
    return readPage(); //go and read the output
  else {
    return "reading failed";
} // End connectAndRead //
String readPage(){
  //read the page, and capture & return everything between '[' and ']'
  stringPos = 0;
  memset( &inString, 0, 32 ); //clear inString memory
  while(true){
    if (client.available()) {
      char c = client.read();
      if (c == '[' ) { //'[' is our begining character
        startRead = true; //Ready to start reading the part
      else if(startRead){
        if(c != ']'){ //']' is our ending character
          inString[stringPos] = c;
          stringPos ++;
        else{
          //got what we need here! We can disconnect now
          startRead = false;
          client.stop();
          client.flush();
          Serial.println("disconnecting.");
          return inString;
} // End readPage //
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
What does this mean?
String pageValue;
String tempValue;
Stop this!
And this.
Use char arrays and pointers, instead.
String readPage(){
          return inString;
This is REALLY ridiculous - taking a global char array containing the data and wrapping it in a String object just so that the function can have something to return.
Hi, thanks for the reply,
Apologies, when the Arduino connects online the Matrix basically loses its current display and flickers random lines of lights on and off all over.
Thanks I will change to char arrays, and look into pointers.
Sorry can you elaborate on this, I am quite new to coding Arduino so am not totally sure what you mean:
"This is REALLY ridiculous - taking a global char array containing the data and wrapping it in a String object just so that the function can have something to return."
#define CLK 10
#define OE  11
#define LAT 12
#define A   A8
#define B   A9
#define C   A10
#define D   A11
You have your matrix connected to the SPI pins that the Arduino uses to communicate with the Ethernet shield.
You have a function, readPage() that collects data into a global array, inString. Does that function need to return anything, when the data is already in a global place? No, it does not. But, you have it wrap the data in an instance of a class that is known to have problems.
That function is only called by connectAndRead(), which doesn't do anything with the data that was read. It simply returns the object that was created to wrap the global data.
The connectAndRead() function is called in two places. Each of them simply prints the data that is returned somewhere (to the serial port or to the matrix). In both of those cases, the data has to be extracted from the wrapper, so the overhead of passing global data wrapped in a leaky mess is completely unnecessary.
