ok so what's going on here?.... whatever the Ground Voltage is determines output voltage?..
0v = 5v out
4v in = 9v out?
Is this simply differential? ....
0v = 5v out
4v in = 9v out?
Yes, the regulator give you 5V above the reference pin voltage. If you ground the reference pin the output is 5V. Since the 4.3V Zener is acting as a 4.3V regulator you should get 9.3V on the output.
He is feeding some back with R1 so he could be getting 9 volts
R1 provides bias current for the zener, so it gives a stable voltage = 4.3V. There is probably not enough current
flowing out of the v.reg reference pin to properly bias the zener into its stable-voltage region without R1.
0v = 5v out
4v in = 9v out?
This makes no sense. You can't get 5V out for 0v in. To turn on the ckt properly, you need Vin at least 2V
higher than Vout. [D1 does nothing during normal operation, so don't confuse with that].
If OP reading something other than approx 9.3V [+/5%] out, then he has it wired wrong.
i'm not reading any voltage since i've not built one!
i want to know how this works, not telling you what it's doing!
All those regulators do is to hold its output at a given voltage above its adj / gnd pin. For 7805, the output pin is 5v above adj / gnd.
So if you raise the potential on the adj/gnd pin, you will raise the output voltage.
Assuming of course there is sufficient input voltage.
This is a popular way to expand the output voltage of those puny regulators.
Ah, now it finally dawned on me what you meant by simply differential. As others indicated, the result isn't
differential, the zener voltage and the v.reg voltage superimpose, ie they are both in the same direction
being in the positive direction w.r.t. ground potential. It's 4.3V + 5V, not 5V - 4.3V.
got it - thanks
