Topic: AD7747 - reading issue (Read 285 times) previous topic - next topic
Frayray94
Hi everybody,
I know that the subject was already treated but not for the issue I had.
Purpose:
I want to make a level sensor using a capacitor that I made by myself. I used to copper strips put on a plastic glass and depending on the level of water, the capacitance is changing.
Now, I bought a capacitance to digital converter "AD7747" to read what is exactly the value of my capacitor. I also have an Arduino to communicate with my chip.
Issue:
I am not really familiar with I²C interface and I found on Internet a code written by somebody which seems to work. I understand what the code does but in case of problem, I am not sure to find the right solution.
The thing is:
Send my code to the Arduino --> Ok
Put some Serial.print inside --> Some of them work, others not really. Thus, it seems that it does not enter in certain part of the code.
Actually, I found in the code that the variable "readycap=Wire.read();" is equal to -1 (I print it in the terminal) while it must be equal to 0 to enter in the next part of the code.
Then, my issue is: I don't understand why the value is equal to "-1" and how to resolve this problem.
I put the code below so you can read it and maybe help me.
I want also to clarify that I solder my AD7747 on a adapter but it seems that all connections are good and the wiring connections are the following:
VDD: 5V
GND: 0V
SDA: A4 (on arduino)
SCL: A5 (on arduino)
C(in): floating (I just first want to read 0pF)
I do not use the other one.
Please find also the datasheet of my component:
http://www.analog.com/media/en/technical-documentation/data-sheets/AD7747.pdf
In case of you cannot open the "ino" file:
    #include <Wire.h>                  //include the library for i2c communication
     //int capreadybit = (bitRead(TWDR,0));  //initialize variable readybit to be two wire data register's lsb
      Wire.begin();                   //sets up i2c for operation
      Serial.begin(9600);             // we will monitor this via serial cable
      Wire.beginTransmission(0x48);
      Wire.write(0xBF);
      Wire.write(0x00);
      Wire.endTransmission();
      delay(4);
      Wire.beginTransmission(0x48);   // begins write cycle
      Wire.write(0x07);              //address pointer for cap setup register
      Wire.write(0xA0);              //b'10100000' found from datasheet page 16
      Wire.endTransmission();        //ends write cycle
      delay(4);                      // Wait for data to clock out? I'm not 100% sure why this delay is here (or why it's 4ms)
      Wire.beginTransmission(0x48);   //begins transmission again
      Wire.write(0x09);              //address pointer for capacitive channel excitation register
      Wire.write(0x0E);              //recommended value from datasheet
      delay(4);
      Wire.write(0x0A);              //address pointer for the configuration register
      Wire.write(0x21);              //b'00100001' for continuous conversion, arbitrary VTF setting, and mid-range capacitive conversion time
      Wire.write(0x0B);              //CAP DAC A Register address (Positive pin data)
      Wire.write(0x80);               //b'10111111' for enable Cap DAC A
      Serial.println("Hello!");        //test to make sure serial connection is working
      Wire.beginTransmission(0x48);   //talking to chip
      Wire.write(byte(0x00));                  //status register address
      Wire.requestFrom(0x48,1);       //request status register data
      int readycap;
      Serial.print(readycap);
      if((readycap&0x1)==0){                // ready?
        Serial.println("Data Ready");
        Wire.beginTransmission(0x48); //arduino asks for data from ad7747
        Wire.write(0x01);             //set address point to capacitive DAC register 1
        Wire.endTransmission();       //pointer is set so now we can read the
        Serial.println("Data Incoming");
        Wire.requestFrom(0x48,3);     //reads data from cap DAC registers 1-3
        while(Wire.available()){
          unsigned char hi,mid,lo;      //1 byte numbers
          long capacitance;            //will be a 3byte number
          float pf;                    //scaled value of capacitance
          hi=Wire.read();
          mid=Wire.read();
          lo=Wire.read();
          capacitance=(hi<<16)+(mid<<8)+lo-0x800000;
          pf=(float)capacitance*-1/(float)0x800000*8.192f;
          Serial.print(pf, DEC); //prints the capacitance data in decimal through serial port
          Serial.print(",");
    //Serial.println("Loop Done");
    //Serial.println("  ");
Frayray94
cattledog
Have you confirmed using an i2c scanner program, that the device is seen on the bus at 0x48?
