in description of Arduino Mega I see that "distance between digital pins 7 and 8 is 160 mil (0.16"), not an even multiple of the 100 mil spacing of the other pins"
There are same words in Duemilanove description.
I check Eagle files for Duemilanove. Yes, pin space D7-D8 is 160 mil.
But, in Eagle files for Mega I see pin space D7-D8 only 150 mil.
Is it bug? What is right pin space D7-D8 for Mega?
Of course, 'right space" IMHO should be x100 mil to be compatible with breadboards, but why Mega layout have 150 mil instead of 160 mil?
Please clarify.
I don't think it's just the Italians -- after all, over on this side of the pond we're still dealing with NTSC television and QWERTY keyboards, just to name a few ancient immovable standards.
Ok, "...will be .. move ... to 0.1 grid". Excellent!!!
However, first question - 0.1 grid is 100 mil or 200 mil or ...?
second - starting from what date WILL BE?
third - what WILL be with a lot of current "wrong space" shields?
Still main question - what is CURRENT exact (real) space between D7 and D8.
In reality you can probably easily 'spring' the pins if they are only 0.01 inches out. Quarter of a millimetre is neither here nor there. Pity the same can't be said about .05 inches, then the initial 'cock up' wouldn't matter
I have a cheap Arduino clone from Hong Kong, and the shield fit wasn't as 'nice' as a real one. Once I'd plugged it in and out a couple of times it 'adjusted' itself.
