I have built a simple EMF detector using this tutorial: http://blog.makezine.com/2009/05/15/making-the-arduino-emf-detector/. My daughter is crazy about the TV show "Supernatural" and I am trying to build a simple one for her for Christmas so she can go "demon hunting". If you have seen the show, you'll know what I mean.
It is working well, but I was wondering if there is a simple way to increase it's sensitivity?
I am using 330 Ohm resistors from the pins to the LEDs and a 3.9 M Ohm resistor to the antenna (the code, provided with the tutorial is attached).
// EMF Detector for LED Bargraph v1.0
// 5.12.2009
// original code/project by Aaron ALAI - aaronalai1@gmail.com
// modified for use w/ LED bargraph by Collin Cunningham - collin@makezine.com
#define NUMREADINGS 15 // raise this number to increase data smoothing
int senseLimit = 15; // raise this number to decrease sensitivity (up to 1023 max)
int probePin = 5; // analog 5
int val = 0; // reading from probePin
int LED1 = 11; // connections
int LED2 = 10; // to
int LED3 = 9; // LED
int LED4 = 8; // bargraph
int LED5 = 7; // anodes
int LED6 = 6; // with
int LED7 = 5; // resistors
int LED8 = 4; // in
int LED9 = 3; // series
int LED10 = 2; //
// variables for smoothing
int readings[NUMREADINGS]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // final average of the probe reading
pinMode(2, OUTPUT); // specify LED bargraph outputs
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
Serial.begin(9600); // initiate serial connection for debugging/etc
for (int i = 0; i < NUMREADINGS; i++)
readings[i] = 0; // initialize all the readings to 0
val = analogRead(probePin); // take a reading from the probe
if(val >= 1){ // if the reading isn't zero, proceed
val = constrain(val, 1, senseLimit); // turn any reading higher than the senseLimit value into the senseLimit value
val = map(val, 1, senseLimit, 1, 1023); // remap the constrained value within a 1 to 1023 range
total -= readings[index]; // subtract the last reading
readings[index] = val; // read from the sensor
total += readings[index]; // add the reading to the total
index = (index + 1); // advance to the next index
if (index >= NUMREADINGS) // if we're at the end of the array...
index = 0; // ...wrap around to the beginning
average = total / NUMREADINGS; // calculate the average
if (average > 50){ // if the average is over 50 ...
digitalWrite(LED1, HIGH); // light the first LED
else{ // and if it's not ...
digitalWrite(LED1, LOW); // turn that LED off
if (average > 150){ // and so on ...
digitalWrite(LED2, HIGH);
else{
digitalWrite(LED2, LOW);
if (average > 250){
digitalWrite(LED3, HIGH);
else{
digitalWrite(LED3, LOW);
if (average > 350){
digitalWrite(LED4, HIGH);
else{
digitalWrite(LED4, LOW);
if (average > 450){
digitalWrite(LED5, HIGH);
else{
digitalWrite(LED5, LOW);
if (average > 550){
digitalWrite(LED6, HIGH);
else{
digitalWrite(LED6, LOW);
if (average > 650){
digitalWrite(LED7, HIGH);
else{
digitalWrite(LED7, LOW);
if (average > 750){
digitalWrite(LED8, HIGH);
else{
digitalWrite(LED8, LOW);
if (average > 850){
digitalWrite(LED9, HIGH);
else{
digitalWrite(LED9, LOW);
if (average > 950){
digitalWrite(LED10, HIGH);
else{
digitalWrite(LED10, LOW);
Serial.println(val); // use output to aid in calibrating
I am strictly a basic hobbyist with Arduinos so any help would be greatly appreciated XD
