Topic: Combining raspi and arduino for accurate measurements using crontab (Read 793 times) previous topic - next topic
robtherobot
So I use multiple boards and other electronics, and lately I've discovered a very useful thing that you can do when you combine the arduino and raspberry pi. There is a pre-installed thing called crontab. This allows you to time when a specific action can happen. for example,
Code: [Select]
crontab -e
that opens crontab.
after you've scrolled to the bottom of the helpful messages, there is a empty space for your code or such.
Code: [Select]
* * * * * python ~/example/example/example/example.py
that * * * * * is a time limit of 1 min. So every min that code runs. There is more information on this website. Hope this helps!
Hoi. OMG I SAW A ROBOTA
vffgaston
Code: [Select]
crontab -e
that opens crontab.
Code: [Select]
I am not a UNIX expert, but have some experience on it: you have to have in mind the "accuracy" in terms of time when the proccess is launched. On the other hand, "crontab" is a widely used tool in LINUX (UNIX).
https://www.linuxquestions.org/questions/slackware-14/how-%2Aaccurate%2A-the-cron-daemon-is-713630/
Regards
robtherobot
