Topic: jittery servos (Read 505 times) previous topic - next topic
TomGeorge
Do you have a pair of wires from the supply  to the servos, AND a separate pair of wires from the Mega to the supply.
The aim is for the controller NOT to share power circuit wiring with the servos.
Are you really prototyping on protoboard?
Tom.... :)
Everything runs on smoke, let the smoke out, it stops running....
jremington
#16
Feb 12, 2018, 12:43 am Last Edit: Feb 12, 2018, 12:48 am by jremington
Quote
the fact that the servo power comes via Dupont connection from the breadboard into the servo connector plug.
That is guaranteed to be a problem, which is why I asked about it some time ago.
Breadboard tracks should never be expected to conduct more that a couple hundred mA, and you are asking one to carry up to 7 Amperes. The track is probably burned.
chopperaddict
Hi Tomgeorge, I think you  have misunderstood my Fritzing diagram ? the servos are powered directly from my lab power supply, the arduino is powered via the USB or a 9v cell.  Only the 2 grounds are connected.
Yes, I am using veroboard so I can solder as many connections as possible, do you not approve ?
Hi jremington, I am not sure where you get 7A current from ?  My servo power supply and DMM show a maximum drain for one servo to switch is no more than 250mA.  There is never a time when more than a single servo is switching at the same time ?
Cheers
TomGeorge
Which is why we ask for a proper schematic.
A 9V cell will not keep your arduino powered for long.
A picture of your project  will help, so we can see your component layout please.
Thanks..  Tom... :)
jremington
#19
Feb 12, 2018, 05:01 pm Last Edit: Feb 12, 2018, 05:03 pm by jremington
Quote
Those measurements don't show the full picture. Servos briefly draw the stall current every time they start to move. For small hobby servos, the stall current is around 1 Ampere and sometimes much more. Look up the stall current for your servo and tell us what that is.
slipstick
SG90 stall current is given as 650mA +/-80mA at 5V. So 1A is overdoing it, but not by very much.
Steve
chopperaddict
Hi Tomgeorge
As requested is here is my best attempt at a schematic produced using Fritzing.
I hope it clarifies my layout and design..?
TomGeorge
Steve
Is not overdoing it, always overspec, never justspec. :o :o :o
Tom... :)
TomGeorge
#23
Feb 13, 2018, 10:20 pm Last Edit: Feb 13, 2018, 10:21 pm by TomGeorge
Thanks for circuit;
You are powering the Mega from the same 5V supply?
Tom... :)
chopperaddict
No Tom, the mega is powered from the USB
TomGeorge
What value are your pull down resistors?
How long are your wires from the switches to the Mega and from the Mega to the Servos?
Can you post a picture of your project so we can see  your component layout?
Tom... :)
chopperaddict
#26
Feb 14, 2018, 01:47 pm Last Edit: Feb 14, 2018, 02:05 pm by chopperaddict
Pulldowns are 10K
Pictures of physical system attached, (including an SD card now attached.)
Hope it makes sense, All ***but*** those duponts on headers and into Arduino are soldered, including my little power distribution board at front and centre. left side is mega power, right is power supply for servos alone, both grounds are connected here with black wire.  All duponts are brand new.
Ian
wildbill
So, with that setup, what do you get if you run the most basic of code - move servo to 45, wait a couple of seconds, move to 90, wait etc.
chopperaddict
Just doing some more soldering, to ensure good contacts on the veroboard, so will try your request once that is finished !
Ian
