Topic: Capacitor overheats (Read 1 time) previous topic - next topic
rickduley
I have made a Shield for a UNO to the circuitry in the attachment.  I power it with a standard 9 V battery and it connects with the other boards in the RC network just fine.  However, after a minute or so the capacitor is far to hot to handle and the communication dies.
Is there some obvious reason (given that the board complies with the circuit diagram) for the overheating and consequent failure?
Thanks
saximus
Is it an electrolytic capacitor? Is it oriented correctly? What is its voltage rating?
aarg
Tantalums overheat when they're reversed. The really nasty thing is that they do it randomly - they may run fine backwards for hours or weeks and then suddenly begin to fail.
  ... with a transistor and a large sum of money to spend ...
Please don't PM me with technical questions. Post them in the forum.
larryd
"suddenly begin to fail."
Smoulder, catch fire, explode into many pieces.
No technical PMs.
The last thing you did is where you should start looking.
PaulMurrayCbr
What everyone else said - capacitor wrong way around.
http://paulmurraycbr.github.io/ArduinoTheOOWay.html
srnet
Exploding capacitors, usually caused by fitting them reversed, can cause nasty eye injurires.
At least for the first time you connect up a new circuit, put a pair of safety glasses on.
$50SAT is now Silent (but probably still running)
http://www.50dollarsat.info/
http://www.loratracker.uk/
Budvar10
Arduino clone with ATmega1284P   http://forum.arduino.cc/index.php?topic=277260.0
TomGeorge
Thanks
Can you post a picture of the shield and indicate the capacitor that is over heating please.
Thanks.. Tom.. :)
Everything runs on smoke, let the smoke out, it stops running....
rickduley
Capacitor on left.
larryd
There is a yellow tantalum capacitor on the left.
Make sure polarity is correct and it has a sufficient voltage rating.
No technical PMs.
TomGeorge
#10
May 21, 2017, 02:58 am Last Edit: May 21, 2017, 02:59 am by TomGeorge
If cap 3 is the offending component, then it may be in the wrong way, or just failed during operation.
Is it the 10uF added for the nrf unit?
Tom... :)
rickduley
Yes.  It's the nRF capacitor.
It was the wrong way round.  Thanks to all you people who replied.
larryd
Quote
You are very lucky.
Throw the old one away.
No technical PMs.
Whandall
If the capacitor is for the NRF, it should be placed as close as possible to the chip,
the connector pins with adjacent 3.3V and GND are a good place to solder it to.
A small SMD type fits best.  ;)
Ah, this is obviously some strange usage of the word 'safe' that I wasn't previously aware of. (D.Adams)
