He probado alimentar los circuitos a parte y que la conexion de informacion se haga mediante Arduino, es decir, que los pines de 5V y GND de la placa no los utilizo. Os voy adjuntar el codigo haber si es problema de codigo pero no lo creo...
i++;*
k = 0;*
//Serial.println("Escribiendo en el fichero...");
//while(inBuffer[k] != 42){*
myFile = SD.open("GPS1.CSV", FILE_WRITE); //{*
//Serial.println(inBuffer[k]); // write the GGA sentence*
//inBuffer[k]= p[k];*
//myFile.print(inBuffer[k]);*
if (strncmp(inBuffer, "$GPRMC",6) == 0)*
Serial.print(inBuffer[k]);*
_ /*if(inBuffer[k]=='W')_
Serial.println();*
_ }*/_
Serial.print(inBuffer[7]);*
Serial.print(inBuffer[8]);*
Serial.print(':');*
Serial.print(inBuffer[9]);*
Serial.print(inBuffer[10]);*
Serial.print(':');*
Serial.print(inBuffer[11]);*
Serial.print(inBuffer[12]);*
Serial.print(inBuffer[17]);*
Serial.print(inBuffer[20]);*
Serial.print(inBuffer[21]);*
Serial.print(inBuffer[22]);*
Serial.print(inBuffer[23]);*
Serial.print(inBuffer[24]);*
Serial.print(inBuffer[25]);*
Serial.print(inBuffer[26]);*
Serial.print(inBuffer[27]);*
Serial.print(inBuffer[28]);*
Serial.print(inBuffer[31]);*
Serial.print(inBuffer[32]);*
Serial.print(inBuffer[33]);*
Serial.print(inBuffer[34]);*
Serial.print(inBuffer[35]);*
Serial.print(inBuffer[36]);*
Serial.print(inBuffer[37]);*
Serial.print(inBuffer[38]);*
Serial.print(inBuffer[39]);*
Serial.println();*
myFile.print(inBuffer[7]);*
myFile.print(inBuffer[8]);*
myFile.print(':');*
myFile.print(inBuffer[9]);*
myFile.print(inBuffer[10]);*
myFile.print(':');*
myFile.print(inBuffer[11]);*
myFile.print(inBuffer[12]);*
myFile.print(inBuffer[17]);*
myFile.print(inBuffer[20]);*
myFile.print(inBuffer[21]);*
myFile.print(inBuffer[22]);*
myFile.print(inBuffer[23]);*
myFile.print(inBuffer[24]);*
myFile.print(inBuffer[25]);*
myFile.print(inBuffer[26]);*
myFile.print(inBuffer[27]);*
myFile.print(inBuffer[28]);*
myFile.print(inBuffer[31]);*
myFile.print(inBuffer[32]);*
myFile.print(inBuffer[33]);*
myFile.print(inBuffer[34]);*
myFile.print(inBuffer[35]);*
myFile.print(inBuffer[36]);*
myFile.print(inBuffer[37]);*
myFile.print(inBuffer[38]);*
myFile.print(inBuffer[39]);*
// myFile.print(inBuffer[40]);*
// myFile.print(inBuffer[41]);*
myFile.println();*
myFile.close();
//Serial.println("done.");*
_ /*else {_
// if the file didn't open, print an error:*
Serial.println("error opening test.txt");*
_ }*/_
k++;*
// establish variables for duration of the ping,*
// and the distance result in inches and centimeters:*
long duration, inches, cm;*
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds.*
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:*
pinMode(pingPin, OUTPUT);*
digitalWrite(pingPin, LOW);*
delayMicroseconds(2);*
digitalWrite(pingPin, HIGH);*
delayMicroseconds(5);*
// The same pin is used to read the signal from the PING))): a HIGH*
// pulse whose duration is the time (in microseconds) from the sending*
// of the ping to the reception of its echo off of an object.*
pinMode(pingPin, INPUT);*
duration = pulseIn(pingPin, HIGH);*
// convert the time into a distance*
inches = microsecondsToInches(duration);*
cm = microsecondsToCentimeters(duration);*
Serial.print(inches);*
Serial.print("in, ");*
Serial.print(cm);*
Serial.print("cm");*
Serial.println();*
delay(100);*
if(cm<=70)*
// digitalWrite(13,HIGH);
myservo.write(130);*
delay(1000);*
long durationI, inchesI, cmI;*
durationI = pulseIn(pingPin, HIGH);*
inchesI = microsecondsToInches(durationI);*
cmI = microsecondsToCentimeters(durationI);*
delay(100);*
//digitalWrite(13,LOW);*
myservo.write(30);*
delay(1000);*
long durationD, inchesD, cmD;*
durationD = pulseIn(pingPin, HIGH);*
inchesD = microsecondsToInches(durationD);*
cmD = microsecondsToCentimeters(durationD);*
myservo.write(100);*
delay(1000);*
delay(100);*
if(cmI<cmD)*
Serial.println("girar izquierda");*
myservo2.write(140);*
delay(1000);*
if(cmI>=cmD)*
Serial.println("girar derecha");*
digitalWrite(13,HIGH);*
myservo2.write(60);*
delay(1000);*
if(cm>=71)*
//myservo.write(100);*
myservo2.write(100);*
long microsecondsToInches(long microseconds)
// According to Parallax's datasheet for the PING))), there are*
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per*
// second). This gives the distance travelled by the ping, outbound*
// and return, so we divide by 2 to get the distance of the obstacle.*
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf*
return microseconds / 74 / 2;*
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.*
// The ping travels out and back, so to find the distance of the*
// object we take half of the distance travelled.*
return microseconds / 29 / 2;*
