Not bad for a fritzing schematic, from posts we have seen I didn't even think that was possible.
The 4017 symbol is crap, can't tell what the different pins are.
You also need a 0.1uF cap to Gnd on the Vcc pin of each device.
Anyway, the design won't work. LEDs in series like that will need 12-15V to turn them all on. 74HC595 cannot supply that.
If you have a 12V to 15V source, you can use the '595 to drive NPN transistors that can pull the base of PNP transistors low to source current into the LED anodes.
Your design would need this:
