Couldn't find a breakout for the ZLED7001 chip (one of the many suitable buck chips - needs support circuitry to work). If want many LEDs all switched then a single DC-DC converter makes more sense to supply them I think.
Does anyone have an eagle part for the STCS2ASPR? If you could point me in the direction even for a PowerSO-10 package that would also be very helpful.
brs0906:
Or consider making an Eagle library yourself - its not as hard as you might think (tedious, perhaps, hard: no) - there are lots of Eagle
tutorials out there to step you through it. You can copy packages and symbols from other libraries (alas that is a bit involved, find a tutorial) too.
Ok sofar I am working with the CAT4101 1A constant current sink, for my white LEDs I set the current to 700ma and it runs quite well and use arduino to handle PWM just fine. Now since my design is using a 5v rail and all of these LED's I am using have FV of roughly 3.5 to 3.8v the driver doesn't have to waste much energy on voltage drop so it stays cool, and the led's get warm of course but not unmanageably so. Now what I am considering to reduce component count is to power 2 1 watt LED's in parallel off of one CAT4101, they both can do 350ma so the driver set to 700ma should have no problems handling both in parallel, however since the red LED has a FV of 2.2v and not 3.8 like green, will this cause a current split difference between red and green, and if so how much and how can I calculate that and correct for it?
MarkT:
Depending on your battery voltage a buck or boost constant-current drive module would be the most efficient - only fairly slow PWM works with these from my researches, but the Arduino's default PWM is quite slow.
Most of the controllers for these sort of LEDs have PWM inputs on the board so it's not a problem.
MatCat:
I have been thinking about all of these factors and I know that any sort of linear DC-DC is going to dissipate a LOT of wasted heat and considering the plane is made of foam excess heat is not preferred :).
MatCat:
At least you won't have a problem with airflow...
Actually no I won't ROFL, I just did a mounting test as pictured below, zip-ties go through a flattened copper tube to hold the LED star on which makes direct contact with the copper, this is in turn zip-tied to a wooden dowel, which is hot-glued to a piece of foam. Now the LED star stabalizes at 160F when running at full blast (350ma), the back end of the copper as shown get's up to about 140F, and between the wooden dowel and the foam 111F, where the hot glue is doesn't even get above ambient, so I think all is fine.
But my question remains from above, can I drive both a red (2.2v FV), and a green (3.8v FV) which both have 350ma operating capacity from a 700ma constant current sink and have them equally split the current (5v source), or will I need a resistor on the red to keep it from sucking up more current then green?
I think I missed the bit when we went from 10v battery to 5 v supply, but you could put the red and green in series ( 6v ) and run them from a pwm constant current current device from the main battery?
Actually the primary system battery is roughly 15v, that would be a lot of wasted heat to linearly lose in voltage drop! So instead I am going to power the lighting system with a switching regulator that can provide 4A at about 5.2v. Series would be preferred but the voltage isn't quite enough, I don't know if the UBEC's I have coming are switchable to 6v, if it is I will just run those two in series, there is a .5v drop on the current sink too to keep thought of, that puts the theoretical need at 6.5v, however the green LED is spec'd down to 3.4v, so 3.4v + 2.2v + 0.5v = 6.1, and if the UBEC has 6v selector realistic output will be 6.2, I actually have another 7A UBEC that puts out 6.2, I might just use that one.
Oh another thought on these red and green LED's... The actual LED's will be each on about 1.2 meters of 22 AWG wire, which means in series from + to - there is a travel of about 4.8 meters of 22AWG wire, I wonder what that does to resistance and capacitance, and if it is enough to merit bumping up the total constant current sink to overcome the loss, plus it will all be on PWM so technically it should be able to be a bit higher because of that too, any thoughts?
MatCat:
At these power levels it might drop half a volt along the wire because of resistance. No biggie, but make sure you have enough overhead in the power supply.
MatCat:
All you need to worry about is that is has enough volts to play with.
Grumpy_Mike:
I would not bother about the length it is short enough.
Mind you it will radiate like stink but then you are not going for FCC approval are you.
I hadn't thought of that... like a giant antenna... hrm... any ideas on preventing that?
I will use my SDR and experiment and see if I pick up any odd frequencies from using the lights as is... Mainly RC airplanes have lights so I am not thinking it's going to be a big issues, especially as long as they aren't messing with 433MHz or 1.3GHz hehe.
A question... I am using these cat4101 constant current sink drivers, and I am wondering... SINCE it is constant current, does that mean if I parallel multiple LED's to the driver that each LED will just get LED Count / Current Sink ma of current? Technically having the LED paralleled means that each LED will see 5v, and the sink will only sink 700ma total as that is how it is set, so if I parallel 2 white LED's that at full power consume 700ma each with a forward voltage of 3.5v onto a 700ma sink, then it should in reality split equally the current allowing only 350ma through each, and dissipating 1.25v x2 to heat (.5v is used by current driver), and continue the pattern regardless of the number of LED's... am I correct in my understanding, and or is there more to understand exactly how I would figure it out properly, thanks!
