I am new to Arduino as well as I'm new to electronics, but I was always interested.
I have bought Arduino Due and I'm trying some simple projects, but I found a problem. PWM pins 2-7 do not work. I tried to make them blink led but it didn't work. Is there anything special about those pins that need to be setup or should it work with no modification?
All other PWM pins work OK. Does that mean my pins are broken?
With the test sketch below, I get the expected outputs on a scope on pins 3 to 13 continuously, but strangely intermittent activity on pin 2 - I'll investigate further when I have time.
Jim
#include "Print.h"
int count = 1;
int ledPin = 13; // LED connected to digital pin 13
// Run once, when the sketch starts.
Serial.println("Blink");
count = 0;
// initialize the digital pin as an output:
pinMode(ledPin, OUTPUT);
