What's the length of the wires to the nrf24 and to the mfrc522?
A little history: I found your post because I also have an RF/RFID combination project, and it initially wasn't working. The project is intended to be used by someone other than me, so I thought I'd be clever and wire it up so that the nrf24 module and the mfrc522 module could be connected via rj45 connectors running a patch cord between the arduino board and a mini board with the RF or RFID modules.
I initially had the nrf24 connected by itself and ran some testing. I found that I couldn't connect a patch cord longer than about 8 inches. If I did, the code would hang and not get past my network.update() line (see the Network_Ping example in the RF24Network library) at the beginning of the loop block.
Ok. Fine. I'll use a shorter RF patch cord.
Separately, I made sure my RFID code worked by commenting out all of the radio code. It worked well with a longer patch cord ~5 ft.
As soon as I connect up both modules with all code uncommented, the RF code would hang again. Unplugging the RFID patch cord got it working again.
So, I soldered up a temporary board using a protoboard and put a female header pin close to the Arduino into which I could directly plug in the nrf24 module. Same thing for the RFID.
Success! Shorter connections helped.
Then, to test, I left the nrf24 module connected into the header and used the 8 in patch cord to extend the RFID.
That also worked.
However, when I went to the 5 ft. patch cord, no luck.
To verify my findings, I wanted to test your code to see if the same thing would work with different code. I didn't have an example of the RX code you were using, but searching for ackPayLoad examples, I found the blog at shantamraj.wordpress.com. I had to modify your code to work with my pinouts and to work with his data. I also modified his data a little to receive the RFID_Data you were sending.
Using these code modifications, I got your code to work with his. I found the same cord length issues I was having: the 8 in. cord and the direct connection worked fine, and the 5 ft. cord didn't. Too bad for me. I'll just have to make it work.
However, the modified code is below. This code works for me with 2 Arduino nanos and their respective nrf24 hardware. I've tried to comment the beginning of the lines where I modified your code. I may have missed some.
Your code (TX side):
#include <SPI.h>
#include <RF24.h>
#include <nRF24L01.h>
#include <MFRC522.h>
/****************** User Config ***************************/
/* Hardware configuration: Set up nRF24L01 radio on SPI bus plus pins 7,8 */
/*changed per my setup*/ //RF24 radio(7, 8);
/*changed per my setup*/ RF24 radio(9, 10);
/* RFID interface configuration apart from SPI bus */
/*changed per my setup*/ //#define RfidRst 9 // RFID reset pin
/*changed per my setup*/ //#define RfidSel 10 // RFID select pin
/*changed per my setup*/ #define RfidRst 15 // RFID reset pin
/*changed per my setup*/ #define RfidSel 14 // RFID select pin
/*changed to work with RX from URL*/ //byte rf_Address[6] = { "3_PTX" }; // Radio pipe refernce of this RFIDReader,
/*changed to work with RX from URL*/ const uint64_t pipe[1] = { 0xF0F0F0F0E1LL };
MFRC522 mfrc522(RfidSel, RfidRst); // Instantiate the reader MFRC522
byte RFID_Data[4]; // Data to Rx unit
/*changed to work with RX from URL*/ //bool resetRFID; // Reset data frrom Rx
/*changed to work with RX from URL*/ int resetRFID;
unsigned long prevMillisA;
unsigned long intervalA = 500;
unsigned long rfStatusTimeOut;
byte rfidTxCount;
bool blockMfrc522;
byte RF_OK_Out = 3;
byte RFID_OK_Out = 4;
Serial.println(F("*** STARTING TRANSMITTER *** "));
SPI.begin();
mfrc522.PCD_Init(); // Initialize the MFRC522 reader
// Setup and configure radio
radio.begin();
radio.setChannel(108); // Above most Wifi Channels
radio.setDataRate(RF24_250KBPS);
radio.setRetries(5, 10); // Delay, count
radio.enableAckPayload(); // Allow optional ack payloads
radio.enableDynamicPayloads(); // Ack payloads are dynamic payload
pinMode(RF_OK_Out, OUTPUT);
pinMode(RFID_OK_Out, OUTPUT);
void loop(void)
if (!blockMfrc522) getRFID(); // Read the RFID tag... when not transmitting
if (RFID_Data[0] == 0 && RFID_Data[1] == 0 && RFID_Data[2] == 0 && RFID_Data[3] == 0)
digitalWrite(RFID_OK_Out, LOW); // Handle the RFID led..
digitalWrite(RFID_OK_Out, HIGH);
//if (millis() - prevMillisA > intervalA)
if (blockMfrc522)
prevMillisA = millis();
//blockMfrc522 = true;
send_rfid(); // Transmitt the last read RFID
blockMfrc522 = false;
if (millis() - rfStatusTimeOut > 2000) // Update RF24 comm status
digitalWrite(RF_OK_Out, LOW);
digitalWrite(RF_OK_Out, HIGH);
void send_rfid()
/*changed to work with RX from URL*/ //radio.openWritingPipe(rf_Address); // Open the writing pipe with own reference
/*changed to work with RX from URL*/ radio.openWritingPipe(pipe[0]);
bool rfTxStatus = (radio.write(&RFID_Data, sizeof(RFID_Data))); // Send the RFID info
if (rfTxStatus) // PROBLEM : THIS BOOL NEVER RETRUNS TRUE
if (radio.isAckPayloadAvailable()) // Sent. Now read the Ack Pay load from Rx module..
radio.read(&resetRFID, sizeof(resetRFID)); // If ackPayLoad is True , reset RFID data
/*changed to work with RX from URL*/ //if (resetRFID)
/*changed to work with RX from URL*/ if (resetRFID == 2)
RFID_Data[0] = 0;
RFID_Data[1] = 0;
RFID_Data[2] = 0;
RFID_Data[3] = 0;
/*added to verify data cleared*/ Serial.println("data reset");
rfStatusTimeOut = millis(); // Hold the RF_OK LED
// FUNCTION TO READ RFID TAG AND CONVERT IT TO A 8 BYTE DATA
int getRFID()
// Look for new cards
if (!mfrc522.PICC_IsNewCardPresent()) {
return;
// Select one of the cards
if (!mfrc522.PICC_ReadCardSerial()) {
return;
for (int i = 0; i < mfrc522.uid.size; i++) {
RFID_Data[i] = mfrc522.uid.uidByte[i];
char scannedRFID[10];
sprintf(scannedRFID, "%02X%02X%02X%02X", RFID_Data[0], RFID_Data[1], RFID_Data[2], RFID_Data[3]);
Serial.println(scannedRFID);
mfrc522.PICC_HaltA();
return 1;
Receiver code (based on URL above):
#include<SPI.h>
#include<nRF24L01.h>
#include<RF24.h>
const uint64_t pipe[1] = {0xF0F0F0F0E1LL};
RF24 radio(8, 9);
int rec[1] = {2};
byte RFID_Data[4];
radio.begin();
delay(100);
radio.setAutoAck(true);
radio.openReadingPipe(1, pipe[0]);
radio.startListening();
radio.setRetries(15, 15);
if ( radio.available() ) {
radio.writeAckPayload( 1, rec, sizeof(int) );
radio.read( &RFID_Data, sizeof(RFID_Data) );
Serial.print("Data got is: ");
Hope this helps.
