Hello, When I try to install the driver for my arduino uno rev 2 on windows 7 (64 bit) I get an error saying Process cannot access the file because it is being used by another process.
I am not sure how that is possible.
I followed the instructinos on the website.
Here is the sine if the info from the setupapi.dev.log
sto: {Index Driver Package: C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_neutral_57cec7a18891cb76\arduino.inf} 13:05:22.838
!!! idb: Failed to create driver store entry for 'arduino.inf_amd64_neutral_57cec7a18891cb76', Error = 0x00000020
!!! idb: Failed to register 'arduino.inf', Error = 0x00000020
!!! idb: Error 32: The process cannot access the file because it is being used by another process.
!!! sto: Failed to register driver package 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_neutral_57cec7a18891cb76\arduino.inf'. Error = 0x00000020
sto: {Index Driver Package: exit(0x00000020)} 13:07:23.018
sto: {DRIVERSTORE_IMPORT_NOTIFY_END} 13:07:23.020
sto: Rollback system restore point:
sto: Description = Device Driver Package Install: Arduino LLC (www.arduino.cc) Ports (COM & LPT)
sto: Time = 0ms
sto: Status = 0x00000000 (SUCCESS)
sto: {DRIVERSTORE_IMPORT_NOTIFY_END: exit(0x00000020)} 13:07:23.034
sto: Rolled back driver package import.
!!! sto: Failed to import driver package into Driver Store. Error = 0x00000020
sto: {Stage Driver Package: exit(0x00000020)} 13:07:23.044
!!! sto: Failed to stage driver package to Driver Store. Error = 0x00000020, Time = 155018 ms
sto: {Import Driver Package: exit(0x00000020)} 13:07:23.054
inf: Opened INF: 'c:\users\development024\desktop\arduino-1.0.4\drivers\arduino.inf' ([strings])
! inf: Add to Driver Store unsuccessful
! inf: Error 32: The process cannot access the file because it is being used by another process.
!!! inf: returning failure to SetupCopyOEMInf
inf: {SetupCopyOEMInf exit (0x00000020)} 13:07:23.201
!!! ndv: Driver Package import failed for new device...installing NULL driver.
!!! ndv: Error 32: The process cannot access the file because it is being used by another process.
dvi: {Plug and Play Service: Device Install for USB\VID_2341&PID_0001\6493633393635180B031}
ump: Creating Install Process: DrvInst.exe 13:07:23.208
! ndv: Installing NULL driver!
dvi: Set selected driver complete.
dvi: {DIF_ALLOW_INSTALL} 13:07:23.294
dvi: No class installer for 'Arduino Uno'
dvi: No CoInstallers found
dvi: Default installer: Enter 13:07:23.299
dvi: Default installer: Exit
dvi: {DIF_ALLOW_INSTALL - exit(0xe000020e)} 13:07:23.302
dvi: {DIF_INSTALLDEVICE} 13:07:23.303
dvi: Default installer: Enter 13:07:23.306
! dvi: Installing NULL driver!
dvi: Writing common driver property settings.
dvi: {Restarting Devices} 13:07:23.318
dvi: Restart: USB\VID_2341&PID_0001\6493633393635180B031
dvi: Restart complete.
dvi: {Restarting Devices exit} 13:07:23.364
dvi: {DIF_INSTALLDEVICE - exit(0x00000000)} 13:07:23.368
ump: Server install process exited with code 0x00000000 13:07:23.377
ump: {Plug and Play Service: Device Install exit(00000000)}
ndv: {Update Driver Software Wizard exit(00000020)}
<<< Section end 2013/04/05 13:10:29.079
<<< [Exit status: FAILURE(0x00000020)]
