In case of interest. This is the highest-resolution delta-sigma ADC which I have found relatively easy to use (although you do need to handle the SO-8 package). I was pleased to get slightly better performance than what the data sheet spec promised (2.5 uV RMS noise). Make sure your Vdd and Vref is clean, though (that is, don't just use a USB +5V rail without RC filtering it!). Device is very low-power, so 500 ohms in series with Vdd, and 1 uF cap works OK.
// Arduino program to read Microchip MCP3550-60 using SPI bus
// by John Beale www.bealecorner.com Feb. 9 2012
MCP3550 is a differential input 22-bit ADC (21 bits + sign)
+Fullscale = (+Vref -1 LSB) = 0x1fffff
-Fullscale = (-Vref) = 0x200000
1 LSB => Vref / 2^21 for Vref=2 V, 1 LSB = 0.95 uV
Datasheet Spec: noise = 2.5 uV RMS with Vref = 2.5 V
measured results:
Noise Test setup: Vdd = 5V, +Vin = -Vin = Vref/2, Zin = 500 ohms (2x 1k divider)
with Vref = 0.500 V, RMS noise = 8.60 LSB or 2.05 uV (1 LSB = 0.24 uV)
with Vref = 1.000 V, RMS noise = 4.33 LSB or 2.06 uV (1 LSB = 0.48 uV)
with Vref = 2.048 V, RMS noise = 2.16 LSB or 2.12 uV (1 LSB = 0.98 uV)
with Vref = 4.00 V, RMS noise = 1.24 LSB or 2.37 uV (1 LSB = 1.91 uV)
#include <SPI.h> // use Arduino SPI library
#define CS 8 // bring CS high for ADC sleep mode, low to start new conversion
#define MOSI 11 // MOSI is not used for this device
#define MISO 12 // status and data bits from ADC
#define SCK 13 // SPI clock from Arduino to ADC
int samples = 100; // how many samples to group together for avg. and std.dev
// MCP3550-60 does 15 samples per second (max) or 66.7 msec per sample
SPI.begin();
SPI.setClockDivider(SPI_CLOCK_DIV32); // SPI clock rate < 5 MHz per MCP3550 spec
SPI.setBitOrder(MSBFIRST); // MSB or LSB first
SPI.setDataMode(SPI_MODE3); // rising/falling edge of clock
digitalWrite(CS,HIGH);
pinMode(CS, OUTPUT); // CS (out from Arduino)
pinMode(MOSI, OUTPUT); //MOSI (data out from Arduino)
pinMode(MISO, INPUT); // MISO (data in to Arduino)
pinMode(SCK, OUTPUT); // SCK (serial clock)
Serial.print("# MCP3550-60 ADC-Read v0.2 Feb.9 2012 sample size: ");
Serial.println(samples);
Serial.println("hours,value,stdev,min,max");
} // end setup()
byte r1, r2, r3, r4;
byte OVL, OVH; // overload condition HIGH and LOW, respectively
unsigned int i; // loop counter
unsigned long w;
long x;
long minval, maxval;
double sum, mean, m2, delta, sumsq, variance,stdev;
double hours;
sum = 0;
sumsq = 0;
m2 = 0;
mean = 0;
minval=1E9;
maxval=-1E9;
for (int n=0;n<samples;) {
delayMicroseconds(100);
digitalWrite(CS,LOW); // start next conversion
delay(50); // delay in milliseconds (nominal MCP3550-60 rate: 66.7 msec => 15 Hz)
i=0; // use i as loop counter
do {
i++;
delayMicroseconds(50); // loop keeps trying for up to 1 second
} while ((digitalRead(MISO)==HIGH) && (i < 20000)); // wait for bit to drop low (ready)
w = readword(); // data in: 32-bit word gets 24 bits via SPI port
OVL = ((w & 0x80000000) != 0x00000000); // ADC negative overflow bit (input > +Vref)
OVH = ((w & 0x40000000) != 0x00000000); // ADC positive overflow bit (input < -Vref)
if ((i < 10000)) {
n++;
x = w <<2; // to use the sign bit
x = x/1024; // to move the LSB to bit 0 position
if (x>maxval) maxval = x;
if (x<minval) minval = x;
// Serial.println(x);
delta = x - mean;
mean += delta/n;
if (n > 1) { // from http://en.wikipedia.org/wiki/Algorithms_for_calculating_variance
m2 += delta * (x - mean);
} // end for i..
variance = m2/samples;
stdev = sqrt(variance);
hours = millis()/3600000.0; // convert milliseconds to hours
Serial.print(hours,4);
Serial.print(",");
Serial.print(mean);
Serial.print(",");
Serial.print(stdev);
Serial.print(",");
Serial.print(minval);
Serial.print(",");
Serial.print(maxval);
Serial.println();
} // end main loop()
// read one word from 22-bit ADC device MCP3550
unsigned long readword() {
union {
unsigned long svar;
byte c[4];
} w; // allow access to 4-byte word, or each byte separately
w.c[3] = SPI.transfer(0x00); // fill 3 bytes with data: 22 bit signed int + 2 overflow bits
w.c[2] = SPI.transfer(0x00);
w.c[1] = SPI.transfer(0x00);
w.c[0]=0x00; // low-order byte set to zero
return(w.svar); // return unsigned long word
} // end readword()
