Topic: Bike interface OBD (Read 69597 times) previous topic - next topic
TriB
There is a Sender and Receiver in the messages.
If you are the sender, ignore the response.
ECU: 0x11
You: 0xF1
cyclegadget
Using the l9637 i am facing some bouncing problems, some of you have had similar problems? I send a request and i receive the eco of my request with the answer from the ecu
How did you resolvered?
My answer was to Serial.read() the eco without saving any of it, until I read everything that I sent. I checked for my last byte of my message. You can use "if" statements to watch for any combination you want. Then, I knew the next bytes were from the ECU.
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
Markino76
Hi guys,
I'm working on similar project: I'm using an Arduino Nano V3 to get info from the k-line (OBD1) of my Honda motorbike.
I'd like to use the HW Serial to dump on the Serial Monitor of my PC what I'm getting from the ECU and I'd like to use SoftwareSerial to communicate with the ECU.
I'm also using an opto-circuit to de-couple the 0-5V of the Arduino signals from the 012V of the bike.
To make the story short... I can't find a way to use SoftwareSerial library with a baud of 10400.
I've connected, for test, two Arduino Nano with SoftwareSerial ports and I'm able to dump on the HW Serial Monitor of the second Arduino all I sent from the first but can't patch the SoftwareSerial code to add 10400 baud option.
Can you please help me?
PS: I saw that SoftwareSerial library works on my Arduino Nanos only till 38400baud, if I configure it at 57600 it doesn't works fine, is it normal?
o5i_
Hi, softsearial doesent work, i had the same issues on seeduino. You can fix it by using the other timers in the internal setup, i dont remember where to find them.. but there is a fix... But i recomend you to use the hardware serial for the transmission, works much better...
mehran135
I want to read my car ECU coolant Temp. with using this circuit , please help me to write program .
https://forum.arduino.cc/index.php?action=dlattach;topic=455232.0;attach=210665
songotag
#110
May 31, 2017, 04:58 pm Last Edit: May 31, 2017, 06:11 pm by songotag
Hello o5i_,
I noticed that when the connection is lost, the microcontroller can not reset the connection unless I switch off the circuit supply.
I think the problem comes from :
if (! Tr_3) {
Can you tell me how to make the connection reset (fast init sequence) without turning off the circuit?
thank you !
songotag
Hello o5i_,
if (! Tr_3) {
thank you !
o5i_
#112
Jun 01, 2017, 09:57 am Last Edit: Jun 01, 2017, 10:04 am by o5i_
Hello o5i_,
if (! Tr_3) {
thank you !
Hi, i dont know whats the problem.. for me it works.. on every error or timeout it resets the communication and does a fast init.. i use the opamp circuit.. maybee u need to increase the timings?
Scissor
Hello o5i_,
if (! Tr_3) {
thank you !
I found out that it is necessary to wait for 5000 ms after a communication error (wrong request, timeout etc.) occurs, at least for my Kawasaki Z750 2004. This means that you really have to halt communcation this long, and not try to reconnect inbetween.
songotag
#114
Jun 02, 2017, 05:37 pm Last Edit: Jun 04, 2017, 09:14 am by songotag
EDIT : I found the solution :
I have to add this line :
Code: [Select]
pinMode(TX, OUTPUT);   after
Code: [Select]
if (time > tr_2 + t_03) {   in the Timeout function ;)
io_5, you can add my name to your code if you whant for the 0.7.1 revision ;-)
Scissor
I use my own library for communication. And whenever I lose communication (for instance due to a wrong request that results in a timeout) I reinitiate the entire communication, also the fast init. You can find my library here: https://github.com/Eztys/SimpleKDS
TriB
@o5i_ I did use your code, removed all GPS and SD-card related stuff.
Changed your buffer storing to BlueTooth.println(K_BUFFER), but it did not work.
It always gave me a Timeout. There have been some values transferred from the bike after initialization, but it did not went further...
However, I took my Kawasaki-code, enhanced the buffer and removed the "Start diagnostic session"-command, which seems not needed. Now I successfully receive 64 values :)
I guess my code is a bit more flexible and refers more to the specifications (init response, error handling, timing, keepalive, ect.). Which does not mean, that my code is clean or even "good" :D
Probably I´ll try to create a small SDS solution, first. Then creating something, which works for Honda, Kawasaki & Suzuki.
I´ll keep you up to date! Can´t wait for weekend to come. Hopefully the weather is bad, to make it easier to stay in the garage ;)
AndreKravcenko
Scissor,
i was trying to use your sketch "SimpleKDSbasic", but i couldn´t to compile it.
I get this :
Scissor
#118
Jul 08, 2017, 02:56 pm Last Edit: Jul 08, 2017, 03:08 pm by Scissor
Scissor,
I get this :
I bet you did'nt install the library properly!
OK, my mistake.. I updated the library but forgot to change the example script. :-X  I've just updated the example script, and it compiles on my computer.
AndreKravcenko
Thanks man.... i´ll try again and post my results !! (I count with the help of all of you !! )
