Topic: How to modify the voltage of solar charger? (Read 3005 times) previous topic - next topic
wvmarle
By and large Schottky diodes work the same as a normal diode - key differences are switching speed (very fast), forward voltage drop (low) and reverse current leakage (high - for a diode, that is, in the order of µA normally).
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
falexandru
Then I can mount a Shotky to prevent back-current to the PV panel and a Zener + resistor to regulate voltage to a value more than 4 V (to charge my 3 x 1.2 V NiMH AAA in series), right?
1steve
I have no idea what the 6 volt name means. My best guess is that the panel has enough over head that it will work with a solar controller to deliver 6 volts. I am more familiar with 12 volt panels and I know the no load voltage will be anywhere from 18 to 24 volts. Also the power rating is at the higher voltage. So a 100 watt 12 volt panel will not give 8.33 amps. (100w/12v=8.33a) It will be more likely (100w/18v=5.55a) 5.5amps.
falexandru
I brought the components:
1) 1 N 5822 Shotky diode -  1 pc
2) Z 4 V 3/0.5 W Zener diode  - 1 pc
3) resistor metal oxid 47/1 W 5%- 1 pc
4) resistor 200 Ohm/ 0.25 W - 1 pc
5) white LED 8mm -1 pc
6) Photovoltaic panel (poli-crystal) 1.1W/6V/200mA (note it is a much smaller one than the initial one)- 1 pc
7) 3.5 mm barrel jack - 1 pc
8) 3.5 mm barrel socket - 1 pc
9) black and red 2 wire (the type used for the speakers) - 2 m
10) perfboard  6 mmx4.5 mm - 1 pc
11)1.2 V 800 mAh AAA NiMH batteries - 1 pc
12) the case for the NiMh batteries (3 in series) - 1 pc
13) commuter 2 ways (2 throws?) - 1 pc
+ various PVC stripes, glue and screws, hooks.
Now, first problem to solve is to pick the right Zener out of the pile of diodes I got. I ordered a range of nominal voltages Zeners and  the seller packed all values together (Zeners are some 2 mm length => [emoticon punches to (my) head].
I will post the schematics asap - I am drawing it by hand.
falexandru
#34
May 26, 2018, 09:09 pm Last Edit: Jun 01, 2018, 10:32 pm by falexandru
and here it is the shematics
Parts as in the previous list:
R1 = 47 Ohm 1 W
R2 = 200 Ohm 0,25 W
C1= 4.7 uF (not sure I really need it, I know it may protect the active components from voltage spikes, but I cant figure out whether spikes have any chances to occur).
This time I am planning to solder components on the perfboard, in a clear design, components at some distance one to another.
I would be extremely happy if somebody more experienced than myself could spend some time to check the circuit. Thank you very very much!
I am going to first breadboard components and once everything is OK, I will proceed to the case and wiring design.
The PV panel I use to prototype is smaller (200 mA) and less efficient (poly-ristal vs. mono-crystal) than the one I posted in the beginning. Reason ist double:
- it is three times cheaper - nice in this risky phase
- if Ok, then I can make more circuits than in the case I used the expensive one - that is good for demo purpose.
falexandru
Correction: there are 3 pcs NimH units. Sorry!
ted
Look ok, you don't need C1 for solar panel.
ted
Just put any diode and measure voltage on it.
Wawa
Why R1. A solar panel is a current source (you can short it).
The whole idea of a schottky backflow diode is that you can leave the panel connected to the battery,
so why a SPDT switch.
Why not use a zener on the solar panel side of the schottky diode (post#28),
so the batteries are not drained by the zener leakage when the sun goes down.
Leo..
falexandru
Thank you guys, for your kind decision to have a look on my circuit!
Leo..
R1 is paired with the Zener downhill
Without the switch, the circuit will light the LED during the day as well.  In a later stage of the project, the same battery will be charged by a Savonius wind turbine, so I am planned to replace the switch by an Arduino board to drive the charging.
falexandru
falexandru
falexandru
To keep it as simple as possible and easy to explain, I rather refrain to use a transistor.
Wawa
Try to draw this:
Zener (4.7volt) across solar panel.
Schottky diode from solar panel to battery(+).
Switch between battery(+) and LED circuit (R2).
Leo..
falexandru
#44
May 27, 2018, 09:56 am Last Edit: May 28, 2018, 02:02 pm by falexandru
Thank you @Wawa! I followed your advise - see following.
Here it is the simplified version of the solar charger from (6V;1.1W;200 mA) Photovoltaic panel to 3 series NiMH battaery units (1.2 V; 800 mAh).
The list of components for this simplified version (see picture attached) is the following:
+ Demonstrative solar charger  +
Components's list
1) Shotky diode: 1 N 5822 -  1 pc
2) Zener diode: Z 4 V 3/0.5 W - 1 pc
3) Resistor: 200 Ohm/ 0.25 W - 1 pc
4) LED: white,  8mm -1 pc
5) Photovoltaic panel: poli-crystal 1.1W/6V/200mA - 1 pc
6) Barrel jack:  3.5 mm  - 1 pc
7) Barrel socket: 3.5 mm  - 1 pc
8) Connection wires:  black and red (the type used for the speakers) - 2 m
9) Perfboard:  6 mmx4.5 mm - 1 pc
10) Batteries: 1.2 V, 800 mAh, AAA, NiMH - 3 pcs
11) Case for the 3 units NiMh batteries: 3 in series - 1 pc
12) Switch: 1 pole - 2 throws - 1 pc
+ various PVC stripes, glue and screws, hooks (drawing pending).
+END +
(note that PV is a much smaller one than the initial one)
No more R1, no C1
for this simplified version.
Not sure if I correctly followed:  "Schottky diode from solar panel to battery(+)".
