Hi, i have written a simple program using c# that shows respectively CPU usage, GPU usage, Ram in Use, Download Speed,CPU Temperature, GPU Temperature on a 16x2 LCD display through serial port
It uses CPU-Z, GPU-Z to get CPU-GPU Temperatures
You can press the button on arduino to adjust the backlight brightness
Fantastic! What I've always wanted hehe. However, which are the requirements for it to work? I downloaded the files from the /bin folder and it crashes upon start. I'm at work so I don't have my arduino board here, does it crash because of that?
geort45:
Thanks a lot for your effort,
It can't work without arduino attached and some code edit. You have to open project with visual studio and change perfomance counter properties for cpu/ram/network interface with english string (i am italian) and com port here with your arduino com port
port = new SerialPort("COM3", 9600, Parity.None, 8, StopBits.One);
I got home and connected the arduino, I ran both exes (Arduino+PC+Monitor.vshost and Arduino+PC+Monitor) and neither worked, I mean no window ever showed up. Is this normal without editing the code?
no it can't work without edit code. if you don't change perfomance counter string to english and your network interface string it won't work you only get exception
I really love this project, but I just can't get the program to work. When I run the pre-made application all it does is crash. When I try to run it in Visual Studio there's something wrong with the performance counters, "Category does not exist". I found a part where the names were really weird like "Interfaccia di rete" but I don't know if this is something that needs to be fix, it doesn't seem to make a difference what I change the names to.
