Keypad is not operated in sub-function.
I have made Sensor-valve-LCD-Keypad system.
if I input an weight of water of a height of water using keypad, arduino control the amount of water using sensor.
but code is not operated well, if i compile the code, there is no error.
#include <LiquidCrystal.h>//LCD Header file load
const int sensorIR=0;//IR sensor
const int sensorUS=1;//Ultrasonic sensor
const int sensorRC=2;
const int numRows = 4;//the number of Rows
const int numCols = 4;// The number of Col
const int debounceTime = 30;//pushing time
const int valve=13;
const int threshold = 1;
LiquidCrystal lcd(22,26,30,34,38,42); //lcd number 4, 6, 11, 12, 13, 14
const char keymap[numRows][numCols] = {
  { '1', '2', '3', 'q' },
  { '4', '5', '6', 'w' },
  { '7', '8', '9', 'e' },
  { '*', '0', '#', 'r' }
const int rowPins[numRows] = {6, 7, 8, 9}; //keypad sw4,5,6,7
const int colPins[numCols] = {2, 3, 4, 5}; //keypad sw0,1,2,3
//===================set up=====================================//
  pinMode(valve,OUTPUT);// valve
  //lcd.begin(8,2);//lcd setup
  for (int row = 0; row < numRows; row++)//keypad setup
    pinMode(rowPins[row], INPUT);
    digitalWrite(rowPins[row], HIGH);
  for(int column = 0; column < numCols; column++)
    pinMode(colPins[column], OUTPUT);
    digitalWrite(colPins[column], HIGH);
  Serial.println("MODE");//print on LCD
// ===========grobal constant==========
char attempt[4]; // char of inputs
int ans[4],data; // int of inputs
int z=0;
//=====================getKey====================
char getKey()// getting key from key pad
  char key = 0;
  for (int column = 0; column < numCols; column++)
    digitalWrite(colPins[column], LOW);
    for(int row = 0; row < numRows; row++)
      if(digitalRead(rowPins[row]) == LOW)
        delay(debounceTime);
        while(digitalRead(rowPins[row])==LOW)
        key = keymap[row][column];
  return key;
//============correctpin==================================
void correctPIN() // do this if correct PIN entered
  Serial.println("* ok *");
  data=1000*ans[0]+100*ans[1]+10*ans[2]+ans[3];
  //lcd.setCursor(0,1); // the lcd cursor moves to the second line
  Serial.print(data);
  for(int zzz;zzz<z;zzz++)
    ans[zzz]=0;
//===============incorrect pin   ================
void incorrectPIN() // do this if incorrect PIN entered
  Serial.print("TryAgain");
  Serial.print("MODE");
//================ check pin====================
void checkPIN()
   for (int zz=0; zz<z; zz++) // wipe attempt
    ans[zz]=int(attempt[zz])-48;
    attempt[zz]=0;
  correctPIN();
//===================readKeypad===========================
void readKeypad()// Keypad read
   char key1 = getKey();
  Serial.print("press *");
  if (key1 != 0)                     [b]  //[color=red]========> not operate[/color]
  {[/b]
    switch(key1)
    case '*'://turn on getting keypad system
      z=0;
      Serial.print(key1);
      break;
    case '#':// turn off getting keypad system
      delay(100); // for extra debounce
      if (z!=4)
        incorrectPIN();//check 4 digits number
      {checkPIN();}//move to checkPIN function
      break;
    default:
      attempt[z]=key1;//displace component of array from keypad
      Serial.print(attempt[z]);// print key on lcd
      z++;
//=======================ultrasonic====================
float ultrasonic()//Ultrasonic sensor code
   int valueUS=analogRead(sensorUS);//receive data from sensor
   float rangeUS=valueUS/3.8+25;//change data to mm unit
   delay(10);//10ms delay
   return rangeUS;// return data to height function
//====================IRsensor===========================
float IRsensor()// IR sensor
  float valueIR = analogRead(sensorIR);//receive data from sensor
  float rangeIR;
  if (valueIR>threshold)
  rangeIR=((2914/(valueIR+5))-1)*10;//chagne to data to mm unit
  return rangeIR;//return data to height function
//=============================Height function==================//
void height()//height control system
  readKeypad();// get data from keypad
  digitalWrite(valve,HIGH);// open valve
  while(1)// infinite loop to close valve
  float IRdata =IRsensor();//get data from IRsensor
  float USdata = ultrasonic();//get data from US sensor
  if((data-2+USdata<=IRdata)&&(IRdata<=USdata+data+2))
   digitalWrite(valve,LOW);//close valve
   break;//break while(1)
/*void weight()
  readKeypad();
  while(1)
  flaot rangeRC =loadcell();
  if(data-2<rangeRC<data-2)
    break;
float loadcell()
  float valRC=analogRead(2);
  return valRC;
//======================= main function======================//
  char key = getKey();// get key from keypad
  if (key != 0)
    switch(key)
    case 'q':// calling height function
      height();
      break;
    case 'r':
//      weight();
      break;
my code is not perfect because i didn't program for loadcell. but I made a code for height mode.
the algorithm
1.select mode in void loop(using get key function)
2. height fuction
3. readkeypad ( problem occurs in this fuction. the screen shows "press *" after that there is no response. no progression. if I push q button , "press *" show on screen again.
4. check key or incollect key
5. collect key
6. get data from collect key function.
7. compare 'data' with sensors data
8. close valve.
Pleas help me. I spent so much time to solve this problem. but i couldn't find out the solution.
  if (key != 0)
    switch(key)
      height();
      break;
    case 'r':
      //      weight();
      break;
So pressing 'q' calls height.
That calls read readKeypad.
  if (key1 != 0)
      switch(key1)
Unless you have super-human responses you won't be able to type that fast. The keypad library is non-blocking. It won't wait for you to press the key. You need to restructure.
how do i change the structure to operate well? to make wating time, i insert delay but, it shows same response... too difficult,.
You need to make readKeypad() blocking function. Add a while(key1 == NO_KEY) statement that reads the key in the body.
   key1 = getKey();
This will end when you press some key.
jsy1903:
I never said to insert a delay. Only have one call to getKey. Keep some "states". For example:
  if (key != 0)
    switch(key)
      gettingHeight = true;
      break;
    case 'r':
      gettingWeight = true;
      break;
    case '*':
     // do something
     break;
    case '0' ... '9':
    // collect digits
    break;
