Serial.begin(9600); // open serial port at 9600 baud
if(Serial.available()) { // if anything on port
byte c = Serial.read(); // read one character
for(int i=0; i<8; i++) {
Serial.print(c%2); // print the least significant bit
delay(100);
c /= 2; // move to next significant bit
I want to reverse this process. Help. Binaty code in digital input to text ?
I think what you want to do is define the character instead of reading a character value. So delete the "byte c"line and in the header add a char definition.
This will not work.
In C/C++ "char" is just one single value.
You can use a character array, but you have to use double quotes instead of single ones and curly brackets.
char c[] = {"text"};
This array has 5 values (not 4) because it has a termination character (null character: 0x00) at the end.
The termination character is added automatically in this case.
For more detailed information see: https://www.arduino.cc/en/Reference/String
And to the initial question: I am sorry, I don't understand what the thread opener wants to do.
Yeah I didn't understand exactly what the OP wanted to do too. You can use char(x) to turn a number into a character. So if byte() defines a number then that should be able to be used in char() to make a character. However, I might be totally off.
