Topic: U8g2: Graphics Library for Monochrome OLEDs and LCDs (Read 34640 times) previous topic - next topic
PaulRB
#105
Mar 19, 2017, 03:10 pm Last Edit: Mar 19, 2017, 03:18 pm by PaulRB
don't you also require a special constructor?
Maybe you can add the constructor line for the u8g2 object also.
Yes, but I would not call it very "special"! Here it is:
Code: [Select]
U8G2_KS0108_128X64_F u8g2(U8G2_R0, U8X8_PIN_NONE, U8X8_PIN_NONE, U8X8_PIN_NONE, U8X8_PIN_NONE,
                          /*enable=*/ U8X8_PIN_NONE, /*dc=*/ U8X8_PIN_NONE, /*cs0=*/ U8X8_PIN_NONE,
                          /*cs1=*/ U8X8_PIN_NONE, /*cs2=*/ U8X8_PIN_NONE, /* reset=*/  U8X8_PIN_NONE);   // Set R/W to low!
The DC, CS0, CS1 pins on the display are driven by the pcf8574 chip. The KS0108 does not have a CS2 pin. RESET on the display is connected to the Wemos RST pin so they reset together. I suppose I could/should have written my code to give the Enable pin in the above constructor, but in the end I hard coded it in the U8x8lib.cpp file.
olikraus
PaulRB, ah, yes, all is handled in the call back functions...
But still, I think this clarifys the usage of your approach.
Thanks,
Oliver
jptheripper
#107
Mar 20, 2017, 12:30 am Last Edit: Mar 20, 2017, 01:09 am by jptheripper
Well, sure, port to u8g2 should be there... I hope to get this done once. Thanks for the request.
Oliver
Oliver,
 Are you still porting m2tklib to u8g2? If not is there another solution?
Thank you.
WilliamB
Guys again thank you for all the hard work that went into this. I am running behind, had some medical issues. but today i got my backpack done! Loading the u8g2 lib tomorrow. well later today its 4am and im cross eyed from all the soldering.
My wiring is NOWHERE near the neatness of Paul's. lol
As you can see I have the i2c scanner sketch running and the chips are responding. so at least i know some of the wiring is right  :)
will post once i get display up and running
PaulRB
#109
Mar 25, 2017, 09:43 am Last Edit: Mar 25, 2017, 09:44 am by PaulRB
You are using a Mega? I don't get that. I'm using a Wemos, which has very few pins but does have WiFi. Mega has more than enough pins to run the ks0108 without using extra chips. What's your motivation?
WilliamB
The mega was for testing. I will be using a  esp8266 12F to run the display. the mega was just handy lol.
olikraus
Oliver,
Thank you.
I have started some weeks back, but my spare time is very much limited :-(
It is in my mind, but i can not promise anything.
Oliver
foxnor1
#113
Apr 24, 2017, 08:37 pm Last Edit: Apr 24, 2017, 09:33 pm by foxnor1
hi I'm  nor  form  Syria  I need  some  information  for  my  display it  winstar
wg320240c0 with  raio ra8835ap3n
haw contact  to arduino mega
I don't  find these  display  in ur  library
please  help  me
I'm  don't  find any  information  online
olikraus
https://github.com/olikraus/u8g2/wiki/u8g2setupcpp#ra8835-nhd_240x128
Oliver
foxnor1
#115
May 01, 2017, 06:32 pm Last Edit: May 02, 2017, 10:45 am by foxnor1
thanks  olivar bat I have  a problem any thing  Is dabbling in thes haw I can  changing  form 240X128 to 320X240
olikraus
#117
May 03, 2017, 01:34 pm Last Edit: May 03, 2017, 01:44 pm by olikraus
ok, so you are saying it works a little bit, but instead of the support for 240x128, you need support for 320x240, correct?
I have created an issue for this:
https://github.com/olikraus/u8g2/issues/260
Oliver
foxnor1
#118
May 03, 2017, 01:40 pm Last Edit: May 03, 2017, 01:45 pm by foxnor1
yes  please  I need
My graduation project stands on this
Jama
Hello.
I am hoping you can help me with a problem I am having.
I have a 128xc64 ST970 lcd.
If I use the U8G library it is fine, if I try the U8G2 library with exactly the same setup I get lots of ghosting and artifacting.
Would you have any idea on what could cause this ?
I have attached an image of the code and the respective output on the screen.
Large image link (Imgur)
