Serial Master/Slave problem using serialEvent
I've made Master/Slave via RS485 using serialEvent.
Here is the code for Master :
String inputString = "";         // a string to hold incoming data
boolean stringComplete = false;  // whether the string is complete
String poll = "*00100011110001111;";
int i = 0;
  // initialize serial:
  Serial.begin(19200);
  // reserve 200 bytes for the inputString:
  inputString.reserve(200);
  pinMode(2, OUTPUT);
  poll.setCharAt(1, 'a' + i++);
  if(i > 10) i = 0;
  digitalWrite(2, 1);
  delay(1);
  Serial.println(poll);
  waiting();
  digitalWrite(2, 0);
  delay(1);
  response();
void response() {
  if (stringComplete) {
    Serial.println(inputString);   // echo response from slave device
    // clear the string:
    inputString = "";
void serialEvent() {
  while (Serial.available()) {
    // get the new byte:
    char inChar = (char)Serial.read();
    if(inChar == '-')
      inputString = "-";
      inputString += inChar;
    // if the incoming character is a ";", set a flag
    // so the main loop can do something about it:
    if (inChar == ';') {
      stringComplete = true;
void waiting() {
  while (!(UCSR0A & (1 << UDRE0)))  // Wait for empty transmit buffer
    UCSR0A |= 1 << TXC0;  // mark transmission not complete
  while (!(UCSR0A & (1 << TXC0)));   // Wait for the transmission to complete
Here is the code for Slave :
  pinMode(3, OUTPUT);    // enable pin for rs485
  digitalWrite(3, 0);
  delay(1);
    digitalWrite(3, 1);    // enable send
    delay(1);
    Serial.print(inputString);
    waiting();
    digitalWrite(3, 0);    // enable receive
    delay(1);
    inputString = "";
    if(inChar == '*')
      inputString = "-";
      inputString = inputString.substring(0, 7) + "111222333444555666"
                    + inputString.substring(7);
void waiting() {
The message between Master and Slave is attached, Master start with "*" and Slave start with "-"
The problem is Master always get lack of response from Slave one step,
actually it is acceptable but I wonder if there is a way to make it better,
I knew that serialEvent only work after loop but do not have idea how to solve this.
Any idea is welcome.
Thanks in advance,
Problem solved!
Thanks
Good!
Problem solved!
Useless information, unless you share the solution.
