Hi people, i finished my first project! Its an arduino based midi controller. 3x8 channel multiplexers fed into the arduino and with a usb midi converter its connected to the PC. Arduino is powered via the usb cable the converter uses.
Heres a video Arduino based MIDI controller DIY - YouTube
If you want i could add the code and the schematics!
awesome sounding (and looking) first project !
You definitely need to blog what you've done
thank you
I have some pics of the building process, but i dont really know how and where to make a blog. If i get some free time (university started) i will put some pictures here
ok pics time !
In the beginning it started with 2 buttons that via the arduino usb cable and a software Serial2Midi converter, it performed simple MIDI on off
Then it grew up to be 1 multiplexer wired with 6 pots and those same 2 buttons
Then the desire of more buttons and knobs came and a diy arduino shield was born (Such a genious board arduino is, such a stupid error to make the spacing awkward :-/. With longer headers and some crafty bending its fixable.)
This is the final layout, box is made from 3mm thick very dense fibre board i found on the street. (Someone had thrown away his kitchen drawers and stuff)
Everything in place ready for soldering. It looks like a mess, but i prefer to call it controlled chaos
Close up of the circuitboard - 10 debounce circuits for the 10 buttons
Everything soldered in place
And the box closed.
Here is the code for the midi controller.
Here is the debug code for the controller, helps alot.
If someone wants the schematic, let me know.
I know everything is not fancy and shiny, but hey thats my first box i made and the first arduino project i made.
Many thanks to Addidis for helping me go through all of this
http://www.jeselectronics.com/
ps. sorry for the pics being as url but they are too big.
Very impressive indeed!
I am planning to make a less ambitious MIDI controller to drive 12 pushbuttons (on/off) and 1 analog output (volume)
I would be interested in some details about the multiplexer (hardware, software and model) and the debounce circuits.
Thanks!
Hello to all Arduino and Ableton fans !
Spoocter, thank you for sharing your project with us. I found this usefull page just when I need schematic and informations about multiplexing pots, because I'm also building a midi controller.
I woud be very gratefull if you send me a mail with schematic (nemanjanekic87@gmail.com).
Please, tell me value of the every ressistor that you use.
I have also a few questions. Is it possible to do it without a midi cable, using Serial to midi converter(program), and is the code same then?
Can I use Arduino Mega or Arduino Duemilanove with this code(I have both)?
hallo! topic has not be posted for along time, i was wondering whether you manage to make the jog-wheels for this midi controller spoocter?
Hi!
How did you map Arduino in Virtual DJ? Please answer.
