NASA generated electricity by sending up rockets with a rope attached too them, basically my feeble (compared to Lord Grumpy Mike) understanding of it was between Earth, or rather Ground, now if we go high enough we have the Positive magnetic field, now as a result, electric charge and indeed a good amount of current began to flow.
Let's suppose they build massive high what's the limit, steal rods, glad rods even (just because of amount of sand) send them high sky, right up high, then drop down to ground Teathers...
Question is, can we build, i say we, i'll never personally, but the Human race as a whole or rather the few who think they possibly could even if they could not..... be that Graphene, or Carbine or just Toughened Glass, would this not just be the purest way to produce energy?
once built you may have a case
but the green debt of building such a thing would need to generate a lot of electrons to be green neutral methinks
lots of Brownie points for lateral thinking
Te problem is that this voltage differential is rather variable. ANd can rech quite high voltages. It is normally released in what we call lightninig. Launch a model rocket with a fine wire attached and you can cause teh lightning to hit the launch point. Problem is, that's an awful large amount of energy being released. Many years ago Popular Science had an article about static electricity motors. Problem was, getting a reliable voltage level was a challenge... Changes in weather can really screw things up...
I thought the NASA project worked by dragging a conductor through the earth's magnetic field, which you can do if you're in orbit at an appropriate altitude. But if you're attached to the earth like a building, you're static WRT the magnetic field, so no electricity generation occurs. (This is particularly neat, because you can also run it backward - run a current though a long wire connection two satellites, and you can make it change altitude!) http://www-spof.gsfc.nasa.gov/Education/wtether.html
There's also the electric field differential that people are talking about, but it normally tends to be very low in POWER (while the voltage can be quite high.) Suitable for running electrostatic motors, perhaps, but those tend to be low power devices as well. And the altitudes involved to get significant voltages are already achieved by today's buildings; it's about 100V/meter!
What you really need if you want power is a Dyson Sphere to generate ~4 x 1026 W . If you cannot build that then keep up with the intergalactic neighbours by at least getting a half decent Dyson-Harrop Satellite;
Another essential is a space elevator. The problem with building that is that all known materials will be crushed under their own weight. However if you put a lump of rock into orbit round the Earth you could "drop" a line from it and keep it under tension rather than compression. Not sure how this stands up to winds etc. or what would happen if somebody cut the rope!
I recall seeing the experiment on TV where they winched out the wire from the the shuttle , and the winch sparked and packed up.
They tried it on another shuttle trip and generated quite a bit of voltage.
I remember buying military surplus micro fine twin wire from guided missiles, many moons back, I wonder if any voltage was generated if they were fired from aircraft.
Not that they would have been using 3v3 Vcc on the logic in the TSR2 days, it was all good old transistors.
I am sure a voltage would have been generated. When they work on overhead powerlines they diconnect them but also earth them as wind blowing through the cables can generate enough static to be dangerous.
On a bit of a tangent there is a video on youtube of a guy climbing out of a helicopter to work on a live overhead line!
The satellite wire works because the wire is moving through the Earth's magnetic field - great idea, wonder who thought of it.
I was once quite excited about solar sails, until I saw the figures -
The L'Garde solar sail will produce a maximum thrust of approximately 0.01 newton, which is roughly equivalent to the weight of a "pink packet" of artificial sweetener.
even if the satellite has only a few Kg mass, I will be long dead before it gets anywhere interesting
The Dyson-Harrop Satellite does not rely on the push of the solar wind instead it extracts electrical energy from the plasma
A relatively small Dyson-Harrop satellite using a 1-centimetre-wide copper wire 300 metres long, a receiver 2 metres wide and a sail 10 metres in diameter, sitting at roughly the same distance from the sun as the Earth, could generate 1.7 megawatts of power – enough for about 1000 family homes in the US.
Apparently it is practical to build one of these the main issue seems to be how to get the power from the satellite back to Earth using lasers. No doubt it is not quite that easy but "This satellite is actually something that we can build, using modern technology and delivery methods," Harrop says.
But it's free, and it is constant (it's also a lot higher that the thrust of a typical ion thruster) - operating on a mass of 1kg, your 0.01N will produce an acceleration close to 2000mph per day - and that sail is tiny.
I used to be an operator at a NASA tracking station in the 60s, and some satellites would zoom over in a few minutes, but sometimes we tracked targets like Cassiopeia A , which took hours to record one phase change on the antenna . ( boring, as the teens would say nowadays, but I always felt privileged to be in the scene )
