Topic: Uploading error: Cannot open DFU device 8087:0aba on PC [PARTLY SOLVED USB 3] (Read 15159 times) previous topic - next topic
ballscrewbob
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
Mustang1993
How my device shows up depends on when.  After powering on or pressing master reset the board appears as libusb (WINusb) devices then later changes to a virtual com port Arduino 101 Serial Monitor (COM3).
If you search for my other posts you'll see how I used the dfu-util.exe among other things.
ballscrewbob
I stand duly chastised for missing that.
I also have a USBTINY ASP powered up so missed it altogether.
Had you not mentioned the winusb I would still have missed it.
rcrescencio
Yes, except I can't find where to add an "exception" within McAfee.
ballscrewbob
@ rcrescencio
Think you are in the wrong post but anyway.
Maybe google can help you.
Here is one to start with.
Or drop this into google "add exceptions to McAfee"
rcrescencio
Let's assume McAfee isn't the issue, since I'm able to turn it off.  Can someone post a picture of device manager w/ WinUSB showing?
ballscrewbob
Like this ?
SVGEST
d0ugparker
I found this fixed my Linux upload problem:
Quote
https://forum.arduino.cc/index.php?topic=377080.0
-Dr Doug
Doug
Be positive-in 100 years we're all going to be dead. :wink:
