Topic: Single phase Induction motor control (Read 196 times) previous topic - next topic
Shashank271990
I want to design a control circuit in order to increase the speed of the Induction motor linearly with precision?
What is the simplest solution?
1) Phase control through triac
2) PWM
dave-in-nj
TomGeorge
#2
Nov 24, 2017, 04:09 am Last Edit: Nov 24, 2017, 04:11 am by TomGeorge
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html
Can you post details/spec of you induction motor please.
Some have start and run capacitors, others just run caps.
How precise?
I hope when you say "increase" the speed, you mean control the speed, not make it run faster than what it is designed for?
Thanks... Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
mauried
Very hard to do.
A VFD variable frequency drive might work, but depends on the speed range and the load on the motor.
Much better to use a 3 phase motor.
