Topic: Trouble setting up I2C Battery Monitor with Arudino (Read 425 times) previous topic - next topic
noneused
Hello, I am trying to use an I2C battery monitor on an Arduino UNO powered by an external Li+ battery pack. The part is a Maxim DS2745, and this is the data sheet: https://datasheets.maximintegrated.com/en/ds/DS2745.pdf
I am familiar with how I2C works but I'm having trouble understanding the connections and the pins of the chip. Here is my thinking:
SCL & SDA pins ---> connect to SCL & SDA pins on Arduino
*This is about as much as I'm sure of. The rest is guess work*
PIO -> Unused
SNS->To negative terminal of battery through a resistor and Vss
Vss-> To negative terminal of battery.
CTG-> To Arduino ground
VIN-> To Arduino VIN(???)
Vdd->To positive battery terminal(???)
As you can tell I'm really unsure of which power/ground pins go where according to the data sheet. I'm also confused as tot he Vdd pin connecting to the positive battery terminal through a decoupling terminal. If anyone has used this chip or a similar one before I would love some insight into what I'm looking at wrong. Thank you for any comments or help!
chucktodd
You CANNOT connect the positive terminal of the battery to VIN of the Arduino.  This circuit IS NOT a charge controller.  It is just a monitor circuit.
You need a Charge controller.
Look at figure 3.  Page 6 of the data sheet.  the Pack + and Pack - are where the charge controller connects.
Chuck.
Currently built mega http server, Now converting it to ESP32.
noneused
Hey Chuck, appreciate the reply. I was having trouble understanding what the Pack + and - were, thanks for the clarification. With your clarification I'm better able to understand the schematic.
