So I was wondering if anyone had any ideas that might help me. I need the following code to loop trough a set of mobile numbers with about a minute delay for each. If the Arduino receives a Positive 'yes' message I need this to break the loop and end it. If it receives a 'no' or a negative message I need it to continue its loop. right now I have it successfully compiling but while it delays correctly in the loop and prints the correct messages in the serial monitor it actually only sends a test message to the first number along with the AT commands to send to the next number (in the text message received by the first number) in this code I have included the receive message code yet, as I would like to get the loop working first before I try to break it.
any input at all might help me.
//THis code is sending both messages to first number
#include <GSM.h>
#define PINNUMBER ""
const int buttonPin = 4;
const int ledPin1 = 13;
const int ledPin2 = 12;
int buttonState = 0;
// initialize the library instance
GSM gsmAccess; // include a 'true' parameter for debug enabled
GSM_SMS sms;
// char array of the telephone number to send SMS
const char* number1 = "xxxxxxxxxxxxxxx"; // add any two mobile numbers here with international codes.
const char* number2 = "xxxxxxxxxxxxxxxxx";
// char array of the message
char txtMsg[200]="test";
// connection state
boolean notConnected = true;
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(buttonPin, INPUT);
// initialize serial communications
Serial.println("SMS Messages Sender");
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes
while(notConnected)
if(gsmAccess.begin(PINNUMBER)==GSM_READY)
notConnected = false;
Serial.println("Not connected");
Serial.println("GSM initialized");
buttonState = digitalRead(buttonPin);
sendSMS();
void sendSMS()
digitalWrite(ledPin1, HIGH);
digitalWrite(ledPin2, LOW);
if(buttonState == HIGH) {
buttonState = 1;
if (buttonState == 1) {
digitalWrite(ledPin2, HIGH);
Serial.print("Message to mobile number: ");
Serial.println(number1);
// sms text
Serial.println("SENDING");
Serial.println("Message:");
Serial.println(txtMsg);
// send the message
sms.beginSMS(number1);
sms.print(txtMsg);
Serial.println("\nFirst Message Sent\n");
delay (60000);
Serial.println(number2);
// sms text
// send the message
sms.beginSMS(number2);
sms.print(txtMsg);
sms.endSMS();
Serial.println("\nSecond Message Sent\n");
