I'm trying to use your library with the arduino spi library. sorry to bother you again but can you please help me out with the code?
#include <SPI.h>
#include <SdFat.h>
int CS_pin = 8;
int DCS_pin = 9;
int DREQ_pin = 7;
int XRST_pin = 6;
int MP3_CS_pin = 10;
SdFat sd;
SdFile myFile;
byte dat[10000];
int index = 0;
pinMode(MP3_CS_pin, OUTPUT);
pinMode(CS_pin, OUTPUT);
pinMode(DREQ_pin, INPUT);
pinMode(DCS_pin, OUTPUT);
pinMode(XRST_pin, OUTPUT);
void playSong(){
for(int i = 0; i < index; i++){
SPI.transfer(dat[i]);
digitalWrite(MP3_CS_pin, HIGH);
digitalWrite(CS_pin, HIGH);
digitalWrite(DCS_pin, HIGH);
delay(100);
if (!sd.init(SPI_HALF_SPEED, MP3_CS_pin)) sd.initErrorHalt();
// re-open the file for reading:
if (!myFile.open("song1.mp3", O_READ)) {
sd.errorHalt("error opening song1.mp3 for read");
Serial.println("song1.mp3:");
int data;
while ((data = myFile.read()) >= 0){
Serial.write(data);
dat[index++] = data;
myFile.close();
SPI.begin();
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE1);
//max SDI clock freq = CLKI/7 and (datasheet) CLKI = 36.864, hence max clock = 5MHz
//SPI clock arduino = 16MHz. 16/ 4 = 4MHz -- ok!
SPI.setClockDivider(SPI_CLOCK_DIV4);
digitalWrite(XRST_pin, LOW);
delay(100);
digitalWrite(XRST_pin, HIGH);
delay(5);
// CHIP Write
// sets sci_mode register, SM_SDINEW, SM_TESTS, SM_STREAM. pg 25, 26
byte aux;
digitalWrite(CS_pin, LOW);
delay(1);
SPI.transfer(0x02); //write command
SPI.transfer(0x00); //SDI_MODE register
//extract and send higher byte of data
//0x0400
aux = 0x08A0 >> 8;
SPI.transfer(aux);
//extract and send lower byte of data
aux = 0x08A0 & 0b11111111;
SPI.transfer(aux);
//wait for the chip to finish executing command
while (!DREQ_pin){};
delay(1);
// Start SINE test
digitalWrite(DCS_pin, LOW);
delay(1);
playSong();
delay(200);
sorry to bother you so much but i've been at this for like 2 weeks now and im super frustrated >.<
