Hello
I am implementing a webserver using Arduino Ethernet ,Arduino USB2 Serial as Programmer and Arduino Nightly IDE. I have writen a programm in C. This programm should diplay IP, MAC and SUB Mask Adress on Hyperterminal Screen(Putty,Teraterm etc) when i enter "ping".
For enabling I/O Steam throuhg UART i used this following function :
FILE uart_str=FDEV_SETUP_STREAM(uart_putch,uart_getch, _FDEV_SETUP_RW);
When i build the sketch in Arduino IDE i get following error:
expected primary expression before '.'tocken"
But when i build the same code in AVR Studio 4 i dont get any error.
As far as i know that Arduiono uses AVR GCC libraries accoring to this reason i should not get this error.
It would be very kind of you and great help for me,if you could give me some advices.
Regards
You can see my code bellow,
[/c#include<stdio.h>
//#include<avr\signal.h> diese Header Datei ist veraltet bei Auskommentierung bekommt man warning "this... is obsolete" statt der #include<avr\interrupt.h> benutzen
#define F_CPU 125000UL //Diese Zeile muss vor #include<util\delay.h> stehen sonst bekommt man Warnung
#define BAUD_RATE 19200
#include<avr\io.h>
#include<string.h>
//SPI I/O
#define SPI_PORT PORTB
#define SPI_DDR DDRB
#define SPI_CS PORTB2
//Wiznet W5100 OP Code
#define WIZNET_WRITE_OPCODE 0xF0
#define WIZNET_READ_OPCODE 0x0F
//Wiznet W5100 Registe Adress
#define MR 0x0000 //Mode Register
#define GAR 0x0001 //Getwway Adress: 0x0001 to 0x0004
#define SUBR 0x0005 //Subnet mask address: 0x0005 to 0x0008
#define SAR 0x0009 //Source Hardware Address(MAC): 0x0009 to 0x000E
#define SIPR 0x000F //Source IP Adress: 0x000F to 0x0012
#define RMSR 0x001A //RX Memory Size Register
#define TMSR 0x001B //TX Memory Size Register
//Methode to initialize uart
void uart_init(void)
UBRR0H=((((F_CPU)/(BAUD_RATE))/16)-1)>>8; //set Baud rate
UBRR0L=((((F_CPU)/(BAUD_RATE))/16)-1);
UCSR0B=(1<<RXEN0)|(1<<TXEN0); //enable RX & TX
UCSR0C=(1<<UCSZ01)|(1<<UCSZ00); //Config Uart
void uart_flush(void)
unsigned char dump;
while(UCSR0A &(1<<RXC0))
dump=UDR0;
int uart_putch(char ch, FILE *stream)
if(ch=='\n')
uart_putch(ch,stream);
while(!(UCSR0A&(1<<RXC0)))
UDR0=ch;
return 0;
int uart_getch(FILE *stream)
unsigned char ch=0;
ch=UDR0;
/*Echo the output back to the terminal*/
return ch;
void ansi_cl(void)
//Ansi clear screen: cl=\E[H\E[J Ansi Code zum Bereinigen des Bildschirmes
putchar(27);
putchar('[');
putchar('H');
putchar(27);
putchar('[');
putchar('J');
void ansi_me(void)
//ANSI turn off all attribute: me=\E[0m
putchar(27);
putchar('[');
putchar('0');
putchar('m');
void SPI_Write(unsigned int addr,unsigned char data)
//Active the CS pin
SPI_PORT&=~(1<<SPI_CS);
//Sending Wiznet Write Opcode to indicate that its goona be written
SPDR=WIZNET_WRITE_OPCODE; //SPDR is SPI Data Register for transmission
//Wait for transmission complete.When its complete the SPIF bit of SPI Status Register turns 0
while(!SPSR &(1<<SPIF))
//Start Wiznet Address High Byte transmission
SPDR=((0xFF00)&addr)>>8 ;//Nach der Undverkünpfung wir 8 bit nach recths verlegt
//Wait for Transmission complete
while(!(SPSR&(1<<SPIF)))
//Sending low byte of address
SPDR=addr&0x00FF;
//wait for Transmission complete
//Start data transmission
SPDR=data;
//Deactivate CS pin
SPI_PORT|=(1<<SPI_CS);
unsigned char SPI_Read(unsigned int addr)
//Activate CS pin of Wiznet
//Preparing Wiznet for reading
SPDR=WIZNET_READ_OPCODE;
//wait for Tranmission complete
//Send high byte of Address
SPDR=(0xFF00&addr)>>8;
//Sending low byte of Adress
SPDR=(0x00FF&addr);
//Sending dummy for reading data
SPDR=0x00;
//Deactivation of CS pin
return SPDR;
//Initializing Wiznet Ethernet Controller
void W5100_Init(void)
unsigned char mac_addr[]={0x00,0x16,0x36,0xDE,0x58,0xF6};
unsigned char ip_addr[]={192,168,0,10};
unsigned char sub_mask[]={255,255,255,0};
unsigned char gtw_addr[]={192,168,0,1};
//Setting the Wiznet Mode Register
SPI_Write(MR,0x80);
_delay_ms(10);
printf("Reading MR: %d\n\n", SPI_Read(MR));
//Setting Getway Register
printf("Setting Getway Address:%d.%d.%d.%d\n\n",gtw_addr[0],gtw_addr[1],gtw_addr[2],gtw_addr[3]);
SPI_Write(GAR+0,gtw_addr[0]);
SPI_Write(GAR+1,gtw_addr[1]);
SPI_Write(GAR+2,gtw_addr[2]);
SPI_Write(GAR+3,gtw_addr[3]);
_delay_ms(10);//Wait to set properly
printf("Reading GAR: %d.%d.%d.%d\n\n",SPI_Read(GAR+0),SPI_Read(GAR+1),SPI_Read(GAR+2),\
SPI_Read(GAR+3));
//Setting MAC Address
printf("Setting Source Address Register:%d.%d.%d.%d\n\n",mac_addr[0],mac_addr[1],mac_addr[2],mac_addr[3],mac_addr[4],mac_addr[5]);
SPI_Write((SAR+0),mac_addr[0]);
SPI_Write(SAR+1,mac_addr[1]);
SPI_Write(SAR+2,mac_addr[2]);
SPI_Write(SAR+3,mac_addr[3]);
SPI_Write(SAR+4,mac_addr[4]);
SPI_Write(SAR+5,mac_addr[5]);
printf("Reading SAR:%.2x:%.2x:%.2x:%.2x:%.2x:%2x\n\n",SPI_Read(SAR+0),SPI_Read(SAR+1),SPI_Read(SAR+2),\
SPI_Read(SAR+3),SPI_Read(SAR+4),SPI_Read(SAR+5));
//Setting Submask Register
printf("Setting Submask Register:%d.%d.%d.%d\n\n",sub_mask[0],sub_mask[1],sub_mask[2],sub_mask[3]);
SPI_Write(SUBR+0,sub_mask[0]);
SPI_Write(SUBR+1,sub_mask[1]);
SPI_Write(SUBR+2,sub_mask[2]);
SPI_Write(SUBR+3,sub_mask[3]);
printf("Reading Submask Register:%d.%d.%d.%d\n\n",SPI_Read(SUBR+0),SPI_Read(SUBR+1),SPI_Read(SUBR+2),\
SPI_Read(SUBR+3));
//Setting IP Adress Register
printf("Setting SIPR:%d.%d.%d.%d\n\n",ip_addr[0],ip_addr[1],ip_addr[2],ip_addr[3]);
SPI_Write(SIPR+0,ip_addr[0]);
SPI_Write(SIPR+1,ip_addr[1]);
SPI_Write(SIPR+2,ip_addr[2]);
SPI_Write(SIPR+3,ip_addr[3]);
printf("Reading SIPR:%d.%d.%d.%d\n\n",SPI_Read(SIPR+0),SPI_Read(SIPR+1),SPI_Read(SIPR+2),SPI_Read(SIPR+3));
//Setting Wiznet RX and TX memory size (2KB for RX and TX )
printf("Setting Wiznet RMSR and TMSR\n\n");
SPI_Write(RMSR,0x55);
SPI_Write(TMSR,0x55);
printf("Wiznet is initialized\n");
//Assign I/O stream to UART :-( :-(
int main(void)
//Set PORTD as Output
DDRD=0xff;
PORTD=0x00;
//Define In/Output Stream
stdout=stdin=&uart_str;
//Initialize UART Peripheral
uart_init();
//Clear Screen
ansi_me();
ansi_cl();
ansi_me();
ansi_cl();
uart_flush();
//Iniritialize AVR Mega328 Peripheral
// Set MOSI(PORTB3),SCK(PORTB5), SS(PORTB2) as output, other as input
SPI_DDR=(1<<PORTB3)|(1<<PORTB5)|(1<<PORTB2) ;
//CS deactivate CS pin it is high incative
//Enable SPI, Master Mose 0, set the clock rate fck/2
SPCR=(1<<SPE)|(1<<MSTR);
SPSR|=(1<<SPI2X);
//Initialize the Wiznet W5100
printf("Wiznet W5100 Init\n\n");
W5100_Init();
//Loop forever
for(;;)
return 0;
ode]
