Hi guys im new to Arduino. Just go it and i was following the steps that are given from dongu
to communicate between my Herkulex DRS-0201 and Arduino Uno board i've got. At the start i set the baudrate to 115200 on Arduino and on Herkulex manager is 115200 baudrate and show me that is on COM3 same as on Arduino. But the voltage im using is 9V not as recommended 7.4V as i dont have a charger with that type of voltage. I connected everything the same way as is on the picture in pdf file. While the program is downloading to Aruino uno board the servo motor starts to blinking red(means that somethink is wrong).
So i disconnect the power and usb from the board and i connect back power then usb and red flashing will come back on servo.
On HerkuleX Manager show me that there is communication on COM3 but it wont connect when i click "Connect"
Any ideas, guys that could help me solve the problem. Cheers.
This suggests that the device is connected to the PC. If that is the case, how is the Arduino supposed to talk to it? If it isn't connected to the PC, is it any wonder why the PC can't talk to it?
Hi PaulS, i've got to the task where i control the servo with arduino software.The problem was, where i upload the code on arduino the baudrate was set to:
HerkuleX.begin(57600, RX, TX);
where the default baudrate for HerkuleX servos is 115200 so i change code to:
HerkuleX.begin(115200, RX, TX);
Then in Arduino software, in monitor mode i was able to move the position of the servo as is shown in pdf file, Point4 (2)Test .
But im still having problem with HerkuleX Manager software when i change the setting to the right COM the same as arduino board is connected to and change the baudrate to 115200 and i click "Connect" still HerklueX Manager can't find the HerkuleX Servo model. So i could change the baudrate communication to 57600.
