Why have you got a 1 millisecond delay at the end of your loop?
by accident I was looking for similar projects to mine and I tweaked the code and missed the delay
So I tried the code and now the servo stays at 180 degrees it doesn't return back to 0 after 2 seconds
#include <Servo.h>
Servo myservo1; //first servo
int SHARP_IR_PIN = 1; //analog pin used to connect the sensor
int ledPin = 9; //select pin for the servo
int val = 0; //variable to read the value from the analog pin
int adc_to_cm(int adc) {
return 14251 * pow(adc,-1.17);
myservo1.attach(9); //set up the servo as usual first servo
pinMode(ledPin, OUTPUT); //variable to store the value coming from the sensor
int reading = analogRead(SHARP_IR_PIN); // replace this pin with the analog pin your sensor is connected to
int distance = adc_to_cm(reading);
char buf[50];
sprintf(buf, "Distance: %d, voltage: %.02f, adc: %d\r\n", distance, reading * 5.00 / 1024 , reading);
Serial.print(buf);
if (distance < 40) {
myservo1.write(0);
while (1);
else {
myservo1.write(180);
delay(1500);
