And the question is simply how can I get it working with Arduino? The specs say --> "This module provides 4-wire SPI-89C52 Drive driver, 9S12XS128 program, controller data and user-friendly interface circuit development. Users only need four IO ports to control the LCD.......a variety of interfaces, 3-wire or 4-wire synchronous serial SPI interface mode, IIC two-wire interface mode."
But where can I get the driver/program whatever? Has anyone else used this somewhere?
Short of that, if it is 128x64 oled, it is likely based on SSD1306 from Solomon. The chip supports 3-/4-wire SPI (D0/D1 as SCK/MOSI) and i2c (as SCL/SDA) in serial form. There are many such code pieces out there but writing your own from the datasheet isn't difficult. The trick is to implement a procotol layer (3-/4-wire spi or i2c) and then implement a device layer on top of that so you can switch the underlying protocol without having to change your device or application code.
The 3-wire spi uses 9-bit transmission so read the datasheet to see if it supports padding. Otherwise, you have to use software spi.
