Topic: How to make a counter from 0 to 999 (Read 1 time) previous topic - next topic
westfw
#15
Aug 12, 2017, 11:05 am Last Edit: Aug 12, 2017, 11:08 am by westfw
Indeed.   I was quite surprised that python integer calculations apparently automatically catch overflows and expand the variable into some sort of bignum.  (at least, I assume that not all integers are bignums...)
Code: [Select]
>>> 15*14*13*12*11*10*9*8*7*6*5*4*3*2*16*17*18*19*20*21*22*23+123
25852016738884976640123
You can do "interesting" things when exception processing is a fundamental part of the language...
RayH
#16
Aug 20, 2017, 01:13 pm Last Edit: Aug 20, 2017, 04:40 pm by RayH Reason: to add code
Hi, I did a project to flash non alphanumerical symbols onto a four digit display, although my code does not do exactly what you are looking for, it may help to explain how to access the display.
You could edit the function to give the numbers 0 to 9 and alter the function call to suit your display and count.
Let me know if you're not sure about anything.
Code: [Select]
//sevenSegSymbols
//By Ray Houghton
//Writes random non-alphanumerical characters to 7 segment display
int CB0 = 2; //sets up control bits for four digits
int CB1 = 3;
int CB2 = 4;
int CB3 = 5;
int onDelay = 4; // governs cycle speed
int sym1;
int sym2;
int sym3;
int sym4;
int i;
//For 4 digit 7 segment display
//connect pins 1 2 3 and 4 via 220 resistor to D2 3 4 and 5
//connect pins 5 6 7 8 9 10 and 11 to D6 7 8 9 10 11 12
// for my display, control bits are high and segment bits are low to turn on segments.
pinMode(CB0, OUTPUT); //sets control pins as output
pinMode(CB1, OUTPUT);
pinMode(CB2, OUTPUT);
pinMode(CB3, OUTPUT);
//Map of segments
//  0000
//  5  1
//  5  1
//  6666
//  4  2
//  4  2
//  3333
sym1 = random(1, 15); // Randomly selects which symbols are displayed
sym2 = random(1, 15);
sym3 = random(1, 15);
sym4 = random(1, 15);
for (i=1; i<60; i++)  // This loop causes the display to hold briefly before randomly
                      //selecting next symbols
digitalWrite(CB0, HIGH);
digitalWrite(CB2, LOW);
digitalWrite(CB1, LOW);
digitalWrite(CB3, LOW);
symbols(sym1);  // turns on control bit for symbol 1
                //and calls the routine to display a symbol
    delay(onDelay);
digitalWrite(CB0, LOW);
digitalWrite(CB2, HIGH);
 symbols(sym2);    // turns on control bit for symbol 2
                   //and calls the routine to display a symbol etc. etc.
    delay(onDelay);
digitalWrite(CB1, HIGH);
symbols(sym3);
    delay(onDelay);
digitalWrite(CB3, HIGH);
 symbols(sym4);
    delay(onDelay);
//Symbols function takes a number as an argument and displays a symbol
//that corresponds to the argument. Using the map of segments,
//new symbols can be added to the function as required.
void symbols(int symbolNum)
int SEG0 = 6; //sets up segment bits
int SEG1 = 7;
int SEG2 = 8;
int SEG3 = 9;
int SEG4 = 10;
int SEG5 = 11;
int SEG6 = 12;
int SEG7 = 13;
pinMode(SEG0, OUTPUT);
pinMode(SEG1, OUTPUT);
pinMode(SEG2, OUTPUT);
pinMode(SEG3, OUTPUT);
pinMode(SEG4, OUTPUT);
pinMode(SEG5, OUTPUT);
pinMode(SEG6, OUTPUT);
switch (symbolNum) {
    case 1:
    digitalWrite(SEG0, HIGH); //seg 0 to seg 6 are segment bits HIGH is off LOW is on
    digitalWrite(SEG1, LOW);  //seg 7 is the decimal point
    digitalWrite(SEG2, HIGH);
    digitalWrite(SEG3, HIGH);
    digitalWrite(SEG4, LOW);
    digitalWrite(SEG5, HIGH);
    digitalWrite(SEG6, LOW);
    digitalWrite(SEG7, HIGH);
    case 2:
    digitalWrite(SEG1, HIGH);
    digitalWrite(SEG2, LOW);
    digitalWrite(SEG4, HIGH);
    digitalWrite(SEG5, LOW);
    case 3:
    digitalWrite(SEG3, LOW);
    case 4:
    case 5:
    digitalWrite(SEG6, HIGH);
    case 6:
    case 7:
    digitalWrite(SEG0, LOW);
     case 8:
     case 9:
     case 10:
     case 11:
     case 12:
     case 13:
     case 14:
    default:
