Topic: New device signature 0x1e9803 (Read 309 times) previous topic - next topic
mudassir9999
Aug 11, 2017, 12:13 pm Last Edit: Aug 11, 2017, 12:18 pm by mudassir9999
Hello everybody,
I am trying to bootload Atmega2560V, I am having a hard chance trying to bootload these chips :(, THese chips are set to incorrect fuses - I am running  threads at AVRFreaks and GitHub.
I am pushing 1Mhz to XTAL1 of Atmega2560V and tried burning bootloaders, I am getting an unexpected error
Quote
avrdude: Device signature = 0x1e9803
avrdude: Expected signature for ATmega2560 is 1E 98 01
Strange right.? I know there's no "0x1e9803" such device signature exists.
The full verbose output is here :
Quote
Arduino: 1.8.3 (Windows 10), Board: "ATmega2560, Arduino MEGA pinout, 2.7v, Disabled (default), 1 MHz internal"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Users\mudas\OneDrive\Documents\Arduino\hardware\MegaCore-master\avr/avrdude.conf -v -patmega2560 -cstk500v1 -PCOM4 -b19200 -e -Ulock:w:0x3f:m -Uefuse:w:0xfd:m -Uhfuse:w:0xd6:m -Ulfuse:w:0x62:m
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\mudas\OneDrive\Documents\Arduino\hardware\MegaCore-master\avr/avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.03s
         Double check chip, or use -F to override this check.
avrdude done.  Thank you.
Error while burning bootloader.
option enabled in File -> Preferences.
What could be the issue.? Why it's showing different Device Signature, This is 100% Atmega2560V and it supports MegaCore bootloaders as well, I want to solve this as quickly as possible because I have low deadlines. :( :(
Can I change Device Signature in avrdude.exe and avrdude.config from 0x1e9801 to 0x1e9803 .? so that it works in my case.?
or any other way around.?
Thank you
spycatcher2k
Quote
Have you trie? if not, why not? Were not here to hold your hand when you want to try something, backup the file before making changes, should you mess it up, no harm done.
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
mudassir9999
Thank you very much for replying to my post..
I have edited avrdude.config at atmega2560 section to this..
Quote
# ATmega2560
part
    id               = "m2560";
    desc             = "ATmega2560";
    signature        = 0x1e 0x98 0x03;
    has_jtag         = yes;
    stk500_devcode   = 0xB2;
#    avr910_devcode   = 0x43;
    chip_erase_delay = 9000;
    pagel            = 0xD7;
    bs2              = 0xA0;
    reset            = dedicated;
when i hit burn bootloaders now, it's giving me same error..
Quote
DrAzzy
#3
Aug 11, 2017, 07:42 pm Last Edit: Aug 11, 2017, 07:44 pm by DrAzzy
You edited the wrong avrdude.conf then, I think? The one you need to edit is the one it shows in the verbose output, ie: C:\Users\mudas\OneDrive\Documents\Arduino\hardware\MegaCore-master\avr\avrdude.conf
That said, I'm alarmed that it's reading an unexpected value for the signature, that's usually a bad sign.
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
