Salve a tutti ragazzi, vorrei realizzare un piccolo progetto che consiste nel far brandeggiare una telecamera PTZ con dei comandi impartiti da arduino...il problema sta nel protocollo utilizzato, sono riuscito a trovarne un sorgente, ma purtroppo è scritto in C...dovrei convertirlo in linguaggio masticabile da arduino...vi allego il source code...magari qualcuno riesce a darmi una manina
* Author: Tamir Khason, 2004
* Email: tamir@khason.biz
* Web: http://www.dotnet.us/
* Freeware: Please do not remove this header
* File: P.cs
* Description: PELCO P Protocol Implementation dot.NET Way
* This is GPL software. Do with it as you want, but feed us back any improvements.
* This is a simple class to control a PELCO PTZ camera via RS422/485
* 'P' protocol. It supports all of the commands including UP, DOWN, IN, OUT, LEFT,
* RIGHT, NEAR, FAR, as well as all other extended commands.
* To use this, you need to put a RS232->RS422 adapter on the output
* of your desired serial port.
* The Pelco doesn't return ANY usefull info back, so you only really need 2-wire support
* (one way) communications out.
* Version: 1.4
using System;
using System.Collections;
namespace Pelco
/// <summary>
/// dot.NET Implementation of Pelco P Protocol
/// </summary>
public class P : Pelco
private const byte STX = 0xA0;
private const byte ETX = 0xAF;
#region Pan and Tilt Commands
#region Data1
private const byte FocusFar = 0x01;
private const byte FocusNear = 0x02;
private const byte IrisOpen = 0x04;
private const byte IrisClose = 0x08;
private const byte CameraOnOff = 0x10;
private const byte AutoscanOn = 0x20;
private const byte CameraOn = 0x40;
#endregion
#region Data2
private const byte PanRight = 0x02;
private const byte PanLeft = 0x04;
private const byte TiltUp = 0x08;
private const byte TiltDown = 0x10;
private const byte ZoomTele = 0x20;
private const byte ZoomWide = 0x40;
#endregion
#region Data3
private const byte PanSpeedMin = 0x00;
private const byte PanSpeedMax = 0x40;
#endregion
#region Data4
private const byte TiltSpeedMin = 0x00;
private const byte TiltSpeedMax = 0x3F;
#endregion
#endregion
#region Enums
public enum PresetAction {Set,Clear,Goto}
public enum PatternAction {Start,Stop,Run}
public enum Action {Start,Stop}
public enum LensSpeed {Low=0x00,Medium=0x01,High=0x02,Turbo=0x03}
public enum Pan {Left = PanLeft,Right = PanRight}
public enum Tilt {Up = TiltUp,Down = TiltDown}
public enum Iris {Open = IrisOpen,Close = IrisClose}
public enum Zoom {Wide = ZoomWide,Tele = ZoomTele}
public enum Switch {On,Off}
public enum Focus {Near = FocusNear,Far = FocusFar}
#endregion
#region Extended Command Set
public byte[] Preset(uint deviceAddress, byte preset, PresetAction action)
byte m_action;
switch (action)
case PresetAction.Set:
m_action = 0x03;
break;
case PresetAction.Clear:
m_action = 0x05;
break;
case PresetAction.Goto:
m_action = 0x07;
break;
default:
m_action = 0x03;
break;
return Message.GetMessage(deviceAddress,0x00,m_action,0x00,preset);
public byte[] Flip(uint deviceAddress)
return Message.GetMessage(deviceAddress,0x00,0x07,0x00,0x21);
public byte[] ZeroPanPosition(uint deviceAddress)
return Message.GetMessage(deviceAddress,0x00,0x07,0x00,0x22);
public byte[] AutoScan(uint deviceAddress, Action action)
byte m_action;
if(action == Action.Start)
m_action = 0x09;
m_action = 0x0B;
return Message.GetMessage(deviceAddress,0x00,m_action,0x00,0x00);
public byte[] RemoteReset(uint deviceAddress)
return Message.GetMessage(deviceAddress,0x00,0x0F,0x00,0x00);
public byte[] Zone(uint deviceAddress,byte zone, Action action)
if(zone<0x01 & zone>0x08)
throw new Exception("Zone value should be between 0x01 and 0x08 include");
byte m_action;
m_action = 0x11;
m_action = 0x13;
return Message.GetMessage(deviceAddress,0x00,m_action,0x00,zone);
public byte[] WriteToScreen(uint deviceAddress,string text)
if(text.Length > 40)
text = text.Remove(40,text.Length-40);
System.Text.Encoding encoding = System.Text.Encoding.ASCII;
byte[] m_bytes = new byte[encoding.GetByteCount(text)*8];
int i = 0;
byte m_scrPosition;
byte m_ASCIIchr;
foreach(char ch in text)
m_scrPosition = Convert.ToByte(i/8);
m_ASCIIchr = Convert.ToByte(ch);
Array.Copy(Message.GetMessage(deviceAddress,0x00,0x15,m_scrPosition,m_ASCIIchr),0,m_bytes,i,8);
i = i + 8;
return m_bytes;
public byte[] ClearScreen(uint deviceAddress)
return Message.GetMessage(deviceAddress,0x00,0x17,0x00,0x00);
public byte[] AlarmAcknowledge(uint deviceAddress, uint alarmID)
if(alarmID < 1 & alarmID>8)
throw new Exception("Only 8 alarms allowed for Pelco P implementation");
return Message.GetMessage(deviceAddress,0x00,0x19,0x00,Convert.ToByte(alarmID));
public byte[] ZoneScan(uint deviceAddress,Action action)
byte m_action;
m_action = 0x1B;
m_action = 0x1D;
public byte[] Pattern(uint deviceAddress,PatternAction action)
byte m_action;
switch (action)
case PatternAction.Start:
m_action = 0x1F;
break;
case PatternAction.Stop:
m_action = 0x21;
break;
case PatternAction.Run:
m_action = 0x23;
break;
default:
m_action = 0x23;
break;
public byte[] SetZoomLensSpeed(uint deviceAddress, LensSpeed speed)
return Message.GetMessage(deviceAddress,0x00,0x25,0x00,(byte)speed);
public byte[] SetFocusLensSpeed(uint deviceAddress, LensSpeed speed)
return Message.GetMessage(deviceAddress,0x00,0x27,0x00,(byte)speed);
#endregion
#region Base Command Set
public byte[] CameraSwitch(uint deviceAddress,Switch action)
byte m_action = CameraOnOff;
if(action == Switch.On)
m_action += CameraOnOff; //Maybe wrong !!!
return Message.GetMessage(deviceAddress,m_action,0x00,0x00,0x00);
public byte[] CameraIrisSwitch(uint deviceAddress,Iris action)
return Message.GetMessage(deviceAddress,(byte)action,0x00,0x00,0x00);
public byte[] CameraFocus(uint deviceAddress,Focus action)
public byte[] CameraZoom(uint deviceAddress,Zoom action)
return Message.GetMessage(deviceAddress,0x00,(byte)action,0x00,0x00);
public byte[] CameraTilt(uint deviceAddress,Tilt action, uint speed)
if(speed<TiltSpeedMin)
speed = TiltSpeedMin;
if(speed<TiltSpeedMax)
speed = TiltSpeedMax;
return Message.GetMessage(deviceAddress,0x00,(byte)action,0x00,(byte)speed);
public byte[] CameraPan(uint deviceAddress,Pan action, uint speed)
if(speed<PanSpeedMin)
speed = PanSpeedMin;
if(speed<PanSpeedMax)
speed = PanSpeedMax;
return Message.GetMessage(deviceAddress,0x00,(byte)action,(byte)speed,0x00);
public byte[] CameraPanTilt(uint deviceAddress,Pan panAction, uint panSpeed, Tilt tiltAction, uint tiltSpeed)
byte[] m_bytes = new byte[8];
byte[] m_tiltMessage = CameraTilt(deviceAddress,tiltAction,tiltSpeed);
byte[] m_panMessage = CameraPan(deviceAddress,panAction,panSpeed);
//m_tiltMessage.CopyTo(m_bytes,0);
//m_panMessage.CopyTo(m_bytes,9);
/*m_bytes[0] = m_tiltMessage[0];
m_bytes[1] = m_tiltMessage[1];
m_bytes[2] = m_tiltMessage[2];
m_bytes[3] = (byte)(m_tiltMessage[3]+m_panMessage[3]);
m_bytes[4] = (byte)(+m_panMessage[4]);
m_bytes[5] = (byte)(+m_panMessage[5]);
m_bytes[6] = m_tiltMessage[6];
m_bytes[7] = m_tiltMessage[7];*/
m_bytes = Message.GetMessage(deviceAddress,0x00,(byte)(m_tiltMessage[3]+m_panMessage[3]),
m_panMessage[4],m_tiltMessage[5]);
return m_bytes;
public byte[] CameraStop(uint deviceAddress)
return Message.GetMessage(deviceAddress,0x00,0x00,0x00,0x00);
#endregion
public struct Message
public static byte Address;
public static byte CheckSum;
public static byte Data1,Data2,Data3,Data4;
public static byte[] GetMessage(uint address, byte data1, byte data2, byte data3, byte data4)
if (address<0 & address>32)
throw new Exception("Protocol Pelco P support 32 devices only");
Address = Byte.Parse((address-1).ToString());
Data1 = data1;
Data2 = data2;
Data3 = data3;
Data4 = data4;
CheckSum = (byte)(STX ^ Address ^ Data1 ^ Data2 ^ Data3 ^ Data4 ^ ETX);
return new byte[]{STX,Address,Data1,Data2,Data3,Data4,ETX,CheckSum};
