Hello all.
Is there a simple way to use the button library
http://www.arduino.cc/playground/Code/Button
to do something if the button is held down for a specified amount of time?
Thanks.
Hello all.
Thanks.
Looks pretty straight forward - check for a button press, then check for a boolean stateChange after your time period - if not, do your action.
if (button.stateChanged()) {
if (button.isPressed()) {
//the state has changed and the button is pressed, note the time
pressedStartTime= millis();
//the state has changed and the button is released
if (millis()-pressedStartTime > HOLD_TIME) {
//the button was pressed for HOLD_TIME milliseconds
//do something
Along those lines, not tested.
Thanks.. Looks right but not working. I will have to go into it more when I get some time.
hmm... it looks like stateChanged() is the problem.. it doesnt seem to work..
Could you test this:
#include <Button.h>
Button button = Button(12,PULLUP);
void setup(){
pinMode(13,OUTPUT); //debug to led 13
void loop(){
if(button.stateChanged()){
digitalWrite(13,!digitalRead(13));
Wire your button directly between the pin and ground.
AlphaBeta:
Could you test this:#include <Button.h>
void setup(){
void loop(){
Didn't work..
I did run the button.isPressed fine.
Wish this library did something like this
Button pressMe = button(2, PULLUP);
if (pressMe.held(1000)) someFunction();
Sorry. One need to update the button first, by button.isPressed();
#include <Button.h>
void setup(){
void loop(){
button.isPressed();
That works well here.
New version:
#include <Button.h>
int sleep = 20;
void setup(){
void loop(){
button.isPressed();
if(button.heldFor(1000)){ //this is true as long as the button is pressed after 1000 ms
if(button.held(2000)){ //this is true once, after the button has been held for 2000 ms
sleep *= 2;
delay(sleep);
New lib attached (will upload as soon as it's working)
Button_1-7.zip (2.89 KB)
OMG you ROCK. I tested it and it works. =(
I am having the button send a serial code if held down for 2 seconds.
With this code though it will keep sending the serial until the button is let go.
I think I could use a variable to prevent it from getting sent more then once and will also use the same varible to prevent other buttons from sending serial untill that command is completed.
Try switching from the heldFor to held, it should just be true once.
Glad it worked 8)
Hey AlphaBeta
Thanks for everything. Just got done building the whole project. Did find one bug at this point. I have 7 buttons so far. The press and hold function works the first time but after that the buttons will insta trigger and the hold will no longer work.
Edit: after some more testing the hold just seems intermittent. Works as intended sometimes and not others. I will post the code when I get a chance.
Please do post the code
I cannot reproduce the errors here.
Here is the code. The messrun variable is to stop people from running another button until the device I am talking to clears it.
Edit: there is some redundant code that will be removed. Also I was just thinking that I blindly used the example you made. Can I just use the
If held and take out the heldfor?
#include <Button.h>
// Variables
int Nion1 = 0;
int Nion2 = 0;
int Nion3 = 0;
int Nion4 = 0;
int Nion5 = 0;
int Nion6 = 0;
int Nion7 = 0;
int Nion8 = 0;
int Nion9 = 0;
int sleep = 20;
int messrun = 0;
const int MessLED = 12;
const int HotMicLED = 11;
String annledon;
String annledoff;
String micon;
String micoff;
long pressedStartTime = 0;
//long HOLD_TIME = 2000;
long previousMillis = 0;
long interval = 2000;
// Inputs
Button ann1 = Button(2,PULLUP);
Button ann2 = Button(3,PULLUP);
Button ann3 = Button(4,PULLUP);
Button ann4 = Button(5,PULLUP);
Button ann5 = Button(6,PULLUP);
Button ann6 = Button(7,PULLUP);
Button ann7 = Button(8,PULLUP);
Button ann8 = Button(9,PULLUP);
Button ann9 = Button(10,PULLUP);
// Outputs
const int Mic = 11;
const int ParkAnn = 12;
Serial.begin(19200);
annledon = String("VACTFF.");
annledoff = String("VACT00.");
micon = String("VMCCFF.");
micoff = String("VMCC00.");
pinMode (MessLED, OUTPUT) ;
pinMode (HotMicLED, OUTPUT);
digitalWrite(MessLED, HIGH);
digitalWrite(HotMicLED, HIGH);
char buffer[8];
int index = 0;
char lastRead;
// Print contents of buffer then clear it
void dumpBuffer()
buffer[index] == 0; // add a null terminator to the string in the buffer
//Serial.println(buffer); // print the contents of the buffer
//-----------------------Serial String Compare---------------------------------
if (annledon.compareTo(buffer) == 0){
digitalWrite(MessLED, LOW);
if (annledoff.compareTo(buffer) == 0){
messrun = 0;
if (micon.compareTo(buffer) == 0){
digitalWrite(HotMicLED, LOW);
if (micoff.compareTo(buffer) == 0){
Serial.print("SMOFFF");
//----------------------end Serial String Compare------------------------------
index = 0; //reset the index
for (int i = 0; i < 8; i++)
buffer[i] = 0; // clear the buffer
//---------------------Get Status From Nion------------------------------------
if (millis() - previousMillis > interval) {
previousMillis = millis();
Serial.print("GACT.");
Serial.print("GMIC.");
//--------------------end get status from Nion---------------------------------
//-------------------Read Serial from Nion-------------------------------------
if (Serial.available() > 0)
lastRead = Serial.read();
if (index < 7)
buffer[index++] = lastRead; // append to the buffer
else // buffer overflow - message too long
//Serial.print("Overflow->");
dumpBuffer();
if (lastRead == '.')
if (index == 7)
//Serial.print("GOOD->"); // we have a complete message
else // message too short
//Serial.print("SHORT->"); // we have an incomplete message
dumpBuffer();
//----------------------end read serial from Nion-------------------------------
//--------------------------buttons---------------------------------------------
//-------------------------button 1-----------------------------
ann1.isPressed();
if(ann1.heldFor(1000)){ //this is true as long as the button is pressed after 1000 ms
if(ann1.held(2000)){ //this is true once, after the button has been held for 2000 ms
sleep *= 2;
if(messrun == 0){
Serial.print("SAN1FF.");
messrun = 1;
delay(sleep);
//-------------------------button 2------------------------------
ann2.isPressed();
if(ann2.heldFor(1000)){ //this is true as long as the button is pressed after 1000 ms
if(ann2.held(2000)){ //this is true once, after the button has been held for 2000 ms
sleep *= 2;
if(messrun == 0){
Serial.print("SAN2FF.");
messrun = 1;
delay(sleep);
//-------------------------button 3------------------------------
ann3.isPressed();
if(ann3.heldFor(1000)){ //this is true as long as the button is pressed after 1000 ms
if(ann3.held(2000)){ //this is true once, after the button has been held for 2000 ms
sleep *= 2;
if(messrun == 0){
Serial.print("SAN3FF.");
messrun = 1;
delay(sleep);
//-------------------------button 4------------------------------
ann4.isPressed();
if(ann4.heldFor(1000)){ //this is true as long as the button is pressed after 1000 ms
if(ann4.held(2000)){ //this is true once, after the button has been held for 2000 ms
sleep *= 2;
if(messrun == 0){
Serial.print("SAN4FF.");
messrun = 1;
delay(sleep);
//-------------------------button 5------------------------------
ann5.isPressed();
if(ann5.heldFor(1000)){ //this is true as long as the button is pressed after 1000 ms
if(ann5.held(2000)){ //this is true once, after the button has been held for 2000 ms
sleep *= 2;
if(messrun == 0){
Serial.print("SAN5FF.");
messrun = 1;
delay(sleep);
//-------------------------button 6------------------------------
ann6.isPressed();
if(ann6.heldFor(1000)){ //this is true as long as the button is pressed after 1000 ms
if(ann6.held(2000)){ //this is true once, after the button has been held for 2000 ms
sleep *= 2;
if(messrun == 0){
Serial.print("SAN6FF.");
messrun = 1;
delay(sleep);
//-------------------------button 7------------------------------
ann7.isPressed();
if(ann7.heldFor(1000)){ //this is true as long as the button is pressed after 1000 ms
if(ann7.held(2000)){ //this is true once, after the button has been held for 2000 ms
sleep *= 2;
if(messrun == 0){
Serial.print("SAN7FF.");
messrun = 1;
delay(sleep);
//-------------------------button 8 (Mic on button)------------------------------
ann8.isPressed();
if(ann8.heldFor(1000)){ //this is true as long as the button is pressed after 1000 ms
if(ann8.held(2000)){ //this is true once, after the button has been held for 2000 ms
sleep *= 2;
if(messrun == 0){
Serial.print("SMICFF.");
messrun = 1;
delay(sleep);
//-------------------------button 9 (Cancel button)------------------------------
ann9.isPressed();
if(ann9.heldFor(1000)){ //this is true as long as the button is pressed after 1000 ms
if(ann9.held(2000)){ //this is true once, after the button has been held for 2000 ms
sleep *= 2;
if(messrun == 0){
Serial.print("SCNLFF.");
delay(sleep);
//--------------------------end buttons-------------------------------------
