After much searching I could not find any good examples of using the TC74 with an Arduino except for one Instructable. That inspired me to add TC74 support to a DS1307 based clock and share it with everyone. My project consists of a HD44780 display in 4-bit mode as described in the LiquidCrystal library and a DS1307 on the IIC bus. The code is fairly simple and assumes that the clock is already setup and running. Here it is:
// Date and time functions using a DS1307 RTC
// and temperature from a TC74
// connected via I2C and Wire lib.
// 2011/11/14, Paul Jenkins
// smellin_bacon@yahoo.ca
// Based on lots of stuff I found elsewhere
// and stuff I put together myself. I take
// no credit for anything. I release this in
// the spirit of open, free software. Hopefully
// someone will learn from it as I have learned.
#include <Wire.h>
#include "RTClib.h"
#include <LiquidCrystal.h>
// led pin to blink
#define ledPin 13
// Address of TC74A7 temperature sensor (from datasheet)
// listed in 7-bit form as 1001 111 or 0 1001 111 or 0x4F.
// Check the TC74 datasheet to see which TC74 you have.
#define tc74a7 0x4f
RTC_DS1307 RTC;
// Initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
pinMode(ledPin, OUTPUT); // Setup blink pin as output
// Setup the LCD's number of columns and rows:
lcd.begin(16, 2);
Wire.begin(); // Setup iic/twi
RTC.begin(); // Setup rtc
// Note that this code assumes:
// a) Your DS1307 is running
// b) Your DS1307 is set to the correct date and time
// Storage for temperature
int temp;
// Flag for negative temperature
int neg;
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 0);
// Get date and time into RTC structure
DateTime now = RTC.now();
// Get a reading from the temperature sensor
// talk with tc74
Wire.beginTransmission(tc74a7);
// command is 'read'
Wire.send(0x00);
// end sequence and send bytes
// request 1 byte from sensor
Wire.requestFrom(tc74a7,1);
if (Wire.available()) {
temp = Wire.receive();
neg = false;
if (temp > 127) {
temp = 255 - temp + 1;
neg = true;
// End conversation with TC74
Wire.endTransmission();
lcd.print(now.year(), DEC);
lcd.print('/');
if (now.month()<10)
lcd.print('0');
lcd.print(now.month(), DEC);
lcd.print('/');
if (now.day()<10)
lcd.print('0');
lcd.print(now.day(), DEC);
lcd.print(" ");
// Display temperature
if (neg == true) {
lcd.print('-');
lcd.print(temp, DEC);
// Display degree symbol on LCD
lcd.write(0xdf);
lcd.print('C');
// Move to line 2 of display
lcd.setCursor(0, 1);
if (now.hour()<10)
lcd.print('0');
lcd.print(now.hour(), DEC);
lcd.print(':');
if (now.minute()<10)
lcd.print('0');
lcd.print(now.minute(), DEC);
lcd.print(':');
if (now.second()<10)
lcd.print('0');
lcd.print(now.second(), DEC);
digitalWrite(ledPin, HIGH);
delay(250);
digitalWrite(ledPin, LOW);
// Code something like this can handle reading
// and formatting temperature for LCD.
// I will consider adding this to the next version.
// A PIC program was the inspiration for this - thanks.
char temperature[] = " 000 C";
num = ReadTemp();
// Check for negative temperature
if (num > 127) {
temperature[0] = '-';
num = ~num + 1;
else temperature[0] = ' ';
temperature[1] = num/100 + 48; // 100's
temperature[2] = (num/10)%10 + 48; // 10's
temperature[3] = num%10 + 48; // 1's
temperature[4] = ' '; // find code for degree sym
temperature[5] = 223; // 'C'
// eliminate 0's at beginning
if (temperature[1] == '0') {
temperature[1]=' ';
if (temperature[2]=='0') temperature[2]=' ';
I like the idea of "class-ifying" this device. Since this is only the second Arduino sketch I've written, the details of doing this are beyond me at the moment. However, this is a great opportunity to expand so I will look into it. Perhaps I can take what was done with the RTC and modify it. One this different about the TC74 is can have one of 8 different addresses depending on exactly which part you purchase. You could have up to 8 of these on one bus so there are lots of possibilities for remote sensing.
I've been through the library tutorial and now I'm trying to get the TC74 code wrapped into the library. Still getting weird compilation error but I think I am close. Will try to post my current code in a bit.
Ok, so I've read through the tutorial on libraries and examined the code of several to see how things are done and now I've written a simple library to handle reading from multiple TC74 sensors. The problem is that I'm getting compilation errors under Arduino IDE 1.0 and I'm not sure what to do. Not that I'm expecting anyone to fix the code for me. I need to learn this. What I need is a little nudge in the right direction.
First, the sample sketch that prints the current temperature value to the serial monitor every few seconds:
TC74.h - Library for Microchip TC74 temperature sensors.
Created by Paul Jenkins, November 17, 2011.
Released into the public domain.
#ifndef TC74_h
#define TC74_h
// Allow for compilation in 0022 or 1.0
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include "Wire.h"
class TC74 {
public:
TC74(byte addr);
TC74();
int read();
private:
byte _addr;
#endif
And this is the meat of the library TC74.cpp
TC74.cpp - Library for Microchip TC74 temperature sensors.
#else
#endif
#include "TC74.h"
#include "Wire.h"
//First, the constructor where an address is supplied
TC74::TC74(byte addr) {
// byte _addr;
if (addr == 0) _addr = 0x48;
if (addr == 1) _addr = 0x49;
if (addr == 2) _addr = 0x4a;
if (addr == 3) _addr = 0x4b;
if (addr == 4) _addr = 0x4c;
if (addr == 5) _addr = 0x4d;
if (addr == 6) _addr = 0x4e;
if (addr == 7) {
_addr = 0x4f;
else {
_addr = 0x48; //Set a default address
//Second, a constructor where no address is specified
TC74::TC74(void) {
byte _addr = 0x4f;
int TC74::read(void)
int _temp = 255;
Wire.beginTransmission(_addr);
Wire.write((uint8_t) 0);
Wire.requestFrom(_addr,1);
_temp = Wire.read();
if (_temp > 127) {
_temp = 255 - _temp + 1;
return _temp;
The errors I was getting from the compiler indicated that the compiler was unhappy with the type of variable I was passing to the Wire functions.
My code was calling the Wire.receive method as follows:
Wire.requestFrom( _addr, 1);
Where _addr is defined as type byte
The resulting compiler error is:
R:\sketches\libraries\TC74\TC74.cpp: In member function 'int TC74::read()':
R:\sketches\libraries\TC74\TC74.cpp:49: error: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second:
C:\Arduino\libraries\Wire/Wire.h:54: note: candidate 1: uint8_t TwoWire::requestFrom(int, int)
C:\Arduino\libraries\Wire/Wire.h:53: note: candidate 2: uint8_t TwoWire::requestFrom(uint8_t, uint8_t)
However, if, when calling Wire.receive, I do a cast on the arguments passed
Code can be a bit shorter, here a partial refactoring
#define BASEADDR 0x48
_addr = BASEADDR + addr;
if (addr > 7) _addr = BASEADDR;
TC74::TC74(void)
_addr = BASEADDR;
Wire.write( (uint8_t) 0);
int rv = Wire.endTransmission(); // note the return code indicating connection!! look in the lib for details
Wire.requestFrom( _addr, (uint8_t)1 ); // only cast one is enough
int _temp = Wire.read();
if (_temp > 127)
_temp = 256 - _temp;
return _temp;
The casting problem is caused by the fact that there are two prototypes which are an equal match as you call the function with one uint8_t and one int as the value 1 is interpreted as an int by the compiler.
