Oke Ive got it working now!!!
IR need to pulse ofcourse, so i used David Cuartielles code of the remote control the oscillationWrite() function to make a pulse.
Now it works like a charm, the code is not done yet, but if you put this on your arduino with a ir led on port 13 your lego 8275 bulldozer wil drive forward on a interval of 2 secs
Not bad for me couch first time i play with arduino.
//mode
#define COMBO_DIRECT_MODE 0x01
#define SINGLE_PIN_CONTINUOUS 0x2
#define SINGLE_PIN_TIMEOUT 0x3
#define SINGLE_OUTPUT 0x4
//PWM speed steps
#define PWM_FLT 0x0
#define PWM_FWD1 0x1
#define PWM_FWD2 0x2
#define PWM_FWD3 0x3
#define PWM_FWD4 0x4
#define PWM_FWD5 0x5
#define PWM_FWD6 0x6
#define PWM_FWD7 0x7
#define PWM_BRK 0x8
#define PWM_REV7 0x9
#define PWM_REV6 0xA
#define PWM_REV5 0xB
#define PWM_REV4 0xC
#define PWM_REV3 0xD
#define PWM_REV2 0xE
#define PWM_REV1 0xf
//speed
#define RED_FLT 0x0
#define RED_FWD 0x1
#define RED_REV 0x2
#define RED_BRK 0x3
#define BLUE_FLT 0x0
#define BLUE_FWD 0x4
#define BLUE_REV 0x8
#define BLUE_BRK 0xC
//channel
#define CH1 0x0
#define CH2 0x1
#define CH3 0x2
#define CH4 0x3
//output
#define RED 0x0
#define BLUE 0x1
int IRPin = 13;
int toggle[4] = {0,0,0,0};
pinMode(IRPin, OUTPUT);
digitalWrite(IRPin, LOW);
//Serial.begin(9600);
//delay(2);
ComboMode(BLUE_REV, RED_FWD, CH1);
delay(2000);
void pf_send(int code1, int code2)
int x = 128;
start_stop_bit();
while (x)
oscillationWrite(IRPin, 156);
if (code1 & x) //high bit
high_pause();
else //low bit
low_pause();
x >>= 1; //next bit
x = 128;
while (x)
if (code2 & x) // high bit
high_pause();
else //low bit
low_pause();
x >>= 1; //next bit
start_stop_bit();
delay(10);
void ComboMode(int blue_speed, int red_speed, int channel)
int nib1, nib2, nib3, nib4, i;
//set nibs
nib1 = channel;
nib2 = COMBO_DIRECT_MODE;
nib3 = blue_speed | red_speed;
nib4 = 0xf ^ nib1 ^ nib2 ^ nib3;
for(i = 0; i < 6; i++)
message_pause(channel, i);
pf_send(nib1 << 4 | nib2, nib3 << 4 | nib4);
void SingleOutput(int pwm, int output, int channel)
//set nibs
nib1 = toggle[channel] | channel;
nib2 = SINGLE_OUTPUT | output;
nib3 = pwm;
if(toggle[channel] == 0)
toggle[channel] = 8;
toggle[channel] = 0;
void start_pause()
delayMicroseconds(1014);
void high_pause()
delayMicroseconds(546);
void low_pause()
delayMicroseconds(260);
void tx_pause()
delayMicroseconds(156);
void message_pause(int channel, int count)
unsigned char a = 0;
if(count == 0)
a = 4 - channel + 1;
else if(count == 1 || count == 2)
a = 5;
else if(count == 3 || count == 4)
a = 5 + (channel + 1) * 2;
delayMicroseconds(a * 77);
void start_stop_bit()
//digitalWrite(IRPin, HIGH);
//tx_pause();
//digitalWrite(IRPin, LOW);
start_pause();
void oscillationWrite(int pin, int time) {
for(int i = 0; i <= time/26; i++) {
digitalWrite(pin, HIGH);
delayMicroseconds(13);
digitalWrite(pin, LOW);
