Topic: Simple universal LCD menu code (Read 54292 times) previous topic - next topic
nitro_boy
thanks for the help but I figured that i'm not up to the task so I will learn some basics frst.
Thanks
tunz
Is there any chance that you can share your encoder routine?
Thanks in advance.
rkflyer
First post but thought I would try to give a little back to the forums
I was looking for a simple menu system for a 16x2 LCD,  I wanted it to have a setup mode and a running mode.  What i took was the core code developed by polepole the OP of the this thread and adapted it. Once done I realised given some of the follow on posts it may be of use to others if I trimmed out my code and re posted it.
Compiled and uploaded it uses 3 buttons up, down and select  - to enter the menu system press the up and down together as the arduino is rebooted. Once completed in the setup function it then drops out to the main void loop.
Ive tried to comment it as much as is sensible in order to help another plagarist like me to hack it into what they need. Also given some rough guide on how to switch it to running as a menu based app i.e. the Menu is the core code and not a setup function.
I am no professional coder and generally look for snippets of code other have produced learning from them to achieve what I need.
Hope someone finds it useful
Code posted on following post
Ric
rkflyer
Part 1:
Code: [Select]
/// Adaption of the Simple LCD menu system writen by PolePole - Arduino forums
//I use the 3 wire LCD driver using an 74HC595 chip - Very good at saving pins http://www.stephenhobley.com/blog/2011/02/07/controlling-an-lcd-with-just-3-pins/
// If you use the conventional LiquidCrystal.h comment out the lines with 595 in them and uncomment the conventional ones, of course setting the pin numbers as required
// include the library code for the LCD
// #include <LiquidCrystal.h>
#include <LiquidCrystal595.h>
// initialize the interface pins for the LCD
// LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
LiquidCrystal595 lcd(2,3,4);     // datapin, latchpin, clockpin
//Define Various Variables used throughout
int timer = 0;
byte totalRows = 2;                // total rows of LCD
byte totalCols = 16;               // total columns of LCD
int returndata = 0;                // Used for return of button presses
unsigned long timeoutTime = 0;     // this is set and compared to millis to see when the user last did something.
const int menuTimeout = 20000;     // time to timeout in a menu when user doesn't do anything.
unsigned long lastButtonPressed;   // this is when the last button was pressed. It's used to debounce.
const int debounceTime = 150;      // this is the debounce and hold delay. Otherwise, you will FLY through the menu by touching the button.
const int buttonUp = 8;            // Set pin for UP Button
const int buttonDown = 9;          // Set pin for DOWN Button
const int buttonSelect = 11;             // Set pin for SLELECT Button
const int buttonCancel = 12;             // Set pun for CANCEL Button (No currently used)
int buttonStateUp = 0;             // Initalise ButtonStates
int buttonStateDown = 0;
int buttonState;
int count = 0;                     // Temp variable for void demo
// constants for indicating whether cursor should be redrawn
#define MOVECURSOR 1
#define MOVELIST 2
// Main setup routine
// Setup stuff that needs to be done regardless of whether entering setup mode or not
    // set up the LCD's number of columns and rows:
    lcd.begin(totalCols, totalRows);
    // Turn on the LCD Backlight
    lcd.setLED1Pin(1);
    // initialize the serial communications port:
    // Set Buttons as input for testing whether to enter setup mode
    pinMode(buttonUp, INPUT);
    pinMode(buttonDown, INPUT);
    // Read the Button States
    buttonStateUp = digitalRead(buttonUp);
    buttonStateDown = digitalRead(buttonDown);
// Start Setup Mode if both up and down buttons pressed together
  if (buttonStateUp == HIGH && buttonStateDown == HIGH) {
  byte topItemDisplayed = 0;  // stores menu item displayed at top of LCD screen
  byte cursorPosition = 0;  // where cursor is on screen, from 0 --> totalRows.
  // redraw = 0  - don't redraw
  // redraw = 1 - redraw cursor
  // redraw = 2 - redraw list
  byte redraw = MOVELIST;  // triggers whether menu is redrawn after cursor move.
  byte i=0; // temp variable for loops.
  byte totalMenuItems = 0;  //a while loop below will set this to the # of menu items.
// Create list of Menu Items
  char* menuItems[]={
    "Menu Item 1",
    "Menu Item 2",
    "Menu Item 3",
    "Menu Item 4 ",
    "Menu Item 5",
    "Menu Item 6",
// count how many items are in list.
  while (menuItems[totalMenuItems] != ""){
    totalMenuItems++;
  //subtract 1 so we know total items in array.
  totalMenuItems--;
  lcd.clear();  // clear the screen so we can paint the menu.
  boolean stillSelecting = true;  // set because user is still selecting.
  timeoutTime = millis() + menuTimeout; // set initial timeout limit.
  do   // Run a loop while waiting for user to select menu option.
// Call any other setup actions required and/or process anything else required whilst in setup mode as opposed to things setup regardless of setup mode
// Call read buttons routine which analyzes buttons and gets a response. Default response is 0.
switch(read_buttons())
      // Case responses depending on what is returned from read buttons routine
      case 1:  // 'UP' BUTTON PUSHED
      timeoutTime = millis()+menuTimeout;  // reset timeout timer
      //  if cursor is at top and menu is NOT at top
      //  move menu up one.
      if(cursorPosition == 0 && topItemDisplayed > 0)  //  Cursor is at top of LCD, and there are higher menu items still to be displayed.
        topItemDisplayed--;  // move top menu item displayed up one.
        redraw = MOVELIST;  // redraw the entire menu
      // if cursor not at top, move it up one.
      if(cursorPosition>0)
        cursorPosition--;  // move cursor up one.
        redraw = MOVECURSOR;  // redraw just cursor.
      case 2:    // 'DOWN' BUTTON PUSHED
      // this sees if there are menu items below the bottom of the LCD screen & sees if cursor is at bottom of LCD
      if((topItemDisplayed + (totalRows-1)) < totalMenuItems && cursorPosition == (totalRows-1))
        topItemDisplayed++;  // move menu down one
        redraw = MOVELIST;  // redraw entire menu
      if(cursorPosition<(totalRows-1))  // cursor is not at bottom of LCD, so move it down one.
        cursorPosition++;  // move cursor down one
      case 4:  // SELECT BUTTON PUSHED
      switch(topItemDisplayed + cursorPosition) // adding these values together = where on menuItems cursor is.
      case 0:  // menu item 1 selected
        lcd.clear();
        lcd.print("Run Item1 code");
        lcd.setCursor(0,1);
        lcd.print("from here");
        Serial.print("Menu item ");
        Serial.print(topItemDisplayed + cursorPosition);
        Serial.print(" selected - ");
        Serial.println(menuItems[topItemDisplayed + cursorPosition]);
        delay(2000);
        stillSelecting = false;
      case 1:  // menu item 2 selected
        lcd.clear();
        lcd.print("Run Item2 code");
        lcd.setCursor(0,1);
      case 2:  // menu item 3 selected
        lcd.clear();
        lcd.print("Run Item3 code");
        lcd.setCursor(0,1);
        lcd.print("from here");Serial.print("Menu item ");
      case 3:  // menu item 4 selected
        lcd.clear();
        lcd.print("Run Item4 code");
        lcd.setCursor(0,1);
        lcd.print("from here");Serial.print("Menu item ");       Serial.print("Menu item ");
      case 4:  // menu item 5 selected
        lcd.clear();
        lcd.print("Run Item5 code");
        lcd.setCursor(0,1);
        lcd.print("from here");Serial.print("Menu item ");Serial.print("Menu item ");
      case 5:  // menu item 6 selected
        lcd.clear();
        lcd.print("Run Item6 code");
        lcd.setCursor(0,1);
    //case 8:  //  CANCEL BUTTON PUSHED - Not currently used
    //  stillSelecting = false;
    //  Serial.println("Button held for a long time");
    //  break;
rkflyer
Part 2:
Code: [Select]
    switch(redraw){  //  checks if menu should be redrawn at all.
    case MOVECURSOR:  // Only the cursor needs to be moved.
      redraw = false;  // reset flag.
      if (cursorPosition > totalMenuItems) // keeps cursor from moving beyond menu items.
        cursorPosition = totalMenuItems;
      for(i = 0; i < (totalRows); i++){  // loop through all of the lines on the LCD
        lcd.setCursor(0,i);
        lcd.print(" ");                      // and erase the previously displayed cursor
        lcd.setCursor((totalCols-1), i);
        lcd.print(" ");
      lcd.setCursor(0,cursorPosition);      // go to LCD line where new cursor should be & display it.
      lcd.print(">");
      lcd.setCursor((totalCols-1), cursorPosition);
      lcd.print("<");
      break;  // MOVECURSOR break.
    case MOVELIST:  // the entire menu needs to be redrawn
      redraw=MOVECURSOR;  // redraw cursor after clearing LCD and printing menu.
      lcd.clear(); // clear screen so it can be repainted.
      if(totalMenuItems>((totalRows-1))){  // if there are more menu items than LCD rows, then cycle through menu items.
        for (i = 0; i < (totalRows); i++){
          lcd.setCursor(1,i);
          lcd.print(menuItems[topItemDisplayed + i]);
      else{  // if menu has less items than LCD rows, display all available menu items.
        for (i = 0; i < totalMenuItems+1; i++){
          lcd.setCursor(1,i);
      break;  // MOVELIST break
    if (timeoutTime<millis()){  // user hasn't done anything in awhile
      stillSelecting = false;  // tell loop to bail out.
  while (stillSelecting == true);  //
//End of Start Setup mode if
//End of Void Setup()
// Clear LCD on exit from setup routine
lcd.clear();
// Put your Main code in here
// If you want your main code to be the menu system then copy the contents of void setup into here
// If you do copy void setup copy (then delete) it from the section '// Start Setup Mode if both up and down buttons pressed together' onwards
// Delete the line      'if (buttonStateUp == HIGH && buttonStateDown == HIGH) { '
// Also make sure you delete the last '}' from the end of the void setup, Labeled 'End of Start Setup mode if'
// When your routine runs it will now go straight into the main menu function
lcd.clear();
lcd.print("now void loop");
lcd.setCursor(0,1);
lcd.print(count);
count = count + 1;
// This routine reads the buttons, applys the debounce and returns the result to the calling routine
int read_buttons(){  // you may need to swap "void" with "int" or "byte"
  int returndata = 0;
  if ((lastButtonPressed + debounceTime) < millis()){  // see if it's time to check the buttons again
    // read Up button
    buttonState = digitalRead(buttonUp);
    if (buttonState == HIGH){
      returndata = returndata + 1;
      lastButtonPressed = millis();
    // read Down button
    buttonState = digitalRead(buttonDown);
      returndata = returndata + 2;
    // read Select button
    buttonState = digitalRead(buttonSelect);
      returndata = returndata + 4;
    // read Cancel button - Not used at present
    //buttonState = digitalRead(buttonCancel);
    //if (buttonState == HIGH){
    //  returndata = returndata + 8;
    //  lastButtonPressed = millis();
  return returndata; // this spits back to the function that calls it the variable returndata.
mholguin
Thanks.
With my rotary encoder, I technically only have 1 button. If you were to break out the encoder functions into buttons, it would need a minimum of 3 - up, down, button 3 pressed a short time (<500ms) to select the menu item and button 3 held a longer time (>500ms) to cancel/go back. You could make the "hold button 3" into it's own 4th button - "cancel."
In the code, the cases after switch(read_encoder) correspond to the following button presses:
case 1 - up button
case 2 - down button
case 4 - select button
case 8 - cancel button
(Side note: I use powers of 2 (instead of 1,2,3,4) for the case switch because with the rotary encoder code I use, rotary states can be added up. For instance, if the button is being held down (case 16) while the rotary is being rotated (case 1), you get: 1 + 16 = 17).
This is a rather old thread, but I'm trying to make this work, but I cannot find the definition for the function read_encoder() (it might have gotten lost during an update).
Any help?
bheinz
Any help?
I am also trying to adapt this code and while I admit I am only 10 minutes deep, I have the same rotary_encoder() not declared error.
 If anyone has successfully adapted this (or similar) code I would love to get my hands on it.  This is the first time I have done anything with string or rotary encoders so I am reading everything I can get my hands on.
Thanks
jasonmrc
i am adapting this to work on an 128x64 code oled, how would you go about the totalrows and total cols variables. ?
Part 2:
Code: [Select]
        lcd.setCursor(0,i);
        lcd.print(" ");
      lcd.print(">");
      lcd.print("<");
          lcd.setCursor(1,i);
          lcd.setCursor(1,i);
lcd.clear();
lcd.clear();
lcd.setCursor(0,1);
lcd.print(count);
count = count + 1;
  int returndata = 0;
    // read Up button
    // read Down button
