Ok, the full code is below
Button xBee
#define VERSION "1.00a0"
int BELL= 11;
int localINDICATOR= 7;
int BUTTON = 2;
pinMode(BUTTON, INPUT);
pinMode(BELL, OUTPUT);
pinMode(localINDICATOR, OUTPUT);
// digitalWrite(BELL, HIGH);
char s2 = Serial.read();
digitalWrite(localINDICATOR, LOW);
digitalWrite(BELL, LOW);
// send a capital D over the serial port if the button is pressed
if (digitalRead(BUTTON) == LOW) {
Serial.print('D');
delay(1000); // prevents overwhelming the serial port i increased the delay
digitalWrite(localINDICATOR, HIGH);
if (Serial.available() > 0) {
// Serial.print(s2);
if (Serial.read() == 'K'){
//ring the bell briefly
// Serial.print('k');
delay(10);
if (Serial.read() == 'H'){
delay(10);
// Serial.print('k'); response code - develop later
relay xBee
//this is the device with the relay on it
int globalset = 1;
int indicatorVar = 0;
int timerVar =0; //i was using these three as external variables
int buttonState = 0; // variable for reading the pushbutton status
#define VERSION "1.01"
int REMOTEINDICATOR = 8;
int BELL = 5;
char val;
int lightsetting = 400;
//int BUTTON = 6;
int relay = 2;
pinMode(REMOTEINDICATOR, OUTPUT);
pinMode(relay, OUTPUT);
// digitalWrite(relay, LOW); // set the relay OFF
val=Serial.read();
if (val == 'h'){
if (val == 'D'){
// Serial.print('K');
// timerVar = 1;
digitalWrite(relay, HIGH);
delay(5000);
Cheers, Maraesa
