Topic: How many floating points can Arduino DUE deal with? (Read 311 times) previous topic - next topic
thanhvu94
I need to do the Kalman filter with very small float Q value. Thus, I wonder how many floating points can Arduino DUE deal with?
ard_newbie
#1
May 15, 2017, 02:52 pm Last Edit: May 15, 2017, 02:53 pm by ard_newbie
I tried this code:
Code: [Select]
  Serial.begin(250000);
  float var1 = -2.0 / 3.0;
  Serial.println(var1, 10); // 7 digits precision ?
  double var2 = -2.0 / 3.0;
  Serial.println(var2, 20); // 14+ digits precision ?
/*************    Results    ***************
-0.6666666865
-0.66666666666666660745
MartinL
In Wikipedia the "Double-precision floating-point format" article describes how 64-bit floating point numbers consist of a sign bit, 11-bit exponent and 52-bit mantissa. This has a bit precision of 53, giving you 53*log(2) = 15.9 decimal digits after the decimal point.
An example they give, is that smallest number greater than one (in "sign | exponent | mantissa" format) as being: 0x3ff0 0000 0000 0001. This gives a value of 1.0000000000000002. Note that it's accurate to 15 decimal places and almost 16.
This can be tested on the Due using the simple program below:
Code: [Select]
// Test: set the double to the smallest number greater than 1
union
  double d;                   // double
  struct
    uint64_t mantissa : 52;   // 52 bit mantissa
    uint64_t exponent : 11;   // 11 bit exponent
    uint64_t sign : 1;        // 1 bit sign
  } part;
} doubleFloat;
  doubleFloat.part.mantissa = 0x1;      // Load mantissa
  doubleFloat.part.exponent = 0x3FF;    // Load exponent
  doubleFloat.part.sign = 0x0;          // Load sign
  Serial.print(F("Double: "));
  Serial.println(doubleFloat.d, 16);    // Should output: 1.0000000000000002
void loop() {}
The answer returned from the Due is 1.0000000000000002, therefore the SAM3X8E does support double precision to 15 decimal places.
