Hi all,
Firstly, sorry if this is in the wrong place, and it is rather long.
I've been trying to connect to an Arduino Mega using a USBasp programmer in avrdude and I am consistently getting the following error.
I ran avrdude from terminal with the following command,
avrdude -c usbasp -p m2560 -v -P usb
To which I receive this error:
avrdude: Version 5.11.1, compiled on Nov 5 2012 at 11:07:24
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/opt/local/etc/avrdude.conf"
User configuration file is "/Users/george/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : usbasp
AVR Part : ATMEGA2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : usbasp
Description : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: error: programm enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
I also ran the command with the -F flag, and I get the additional output:
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
avrdude: Expected signature for ATMEGA2560 is 1E 98 01
Additional Information
- I have checked the wiring and it is correct.
- The USBasp has been successfully used to program an Arduino UNO.
- I have also tried bridging the jumper J3 on the USBasp, with no success.
- The Mega in question has been successfully used before, but for some unknown reason it stopped working.
Does anyone know what may be wrong (i.e do I need a new Mega?) ?
I'm running out of things to try.
Thanks in advance,
George.
