IGBTs are typically driven to +15V and -5V on the gate (since IGBTs are designed for higher voltages the
gate voltages are typically higher and the negative gate drive helps reduce the slow turn-off time. If the
application isn't demanding you probably can just use 12V and a standard MOSFET driver...
