GSM3SoftSerial was designed for emulate a serial port by software, not for hardware native serial port. You have to modify it or create a new code for it.
If you can use a serial port emulate by software, RX pin must be a pin with support for interruptions.
is it possible for me to use Original Arduino GSM Library with other GSM shield (not original GSM shield as well) for example from DFRobot? if it could, in which part i must adjust?
the most important is that how to change pin software defined rx and tx (ardunio uno pins 2&3) gsm.h library to hardware 0&1 pins i mean what should we modify in that library to do so?
I did try it out and find the Pin upsetting for GSM in the header file ( GSM3IO.h ) the place -> ( C:\Program Files (x86)\Arduino\libraries\GSM\src). But when I change the pin ports there nothing really happens.
Are there someone that has a suggestion about this?
I was looking at this post and noticed some of you having trouble using hardware serial. I have figured it out with the library I am using. I use it with a Mega and a 3G modem shield. If anyone would like more info on what I did, please reply.
Yes please, I am completely new to this and I am struggling with the 3G modem shield. I can get the example test send sms to work on the Uno, but I need to use a mega to enable the keyboard (unless I rig up a voltage divider and use analogue input). I have changed the example code to use pins 18/19 for TX/RX but I think I am struggling to 1. Communicate and 2. Get the shield to begin
Basis of the project I'm working on is
Hardware -
Funding Mega 2550
DFRobot LCD Keypad Shield
TinySine 3G Shield (Sim5320A)
Operation -
At idle, the LCD displays "Enter Ph Number", the user then enters their phone number using the keypad. Once 10 digits have been entered, the LCD writes "Press # to Send", the user then presses hash and I wish for the Arduino to send a SMS to a set number (UTCPhone String). The message will contain the entered user phone number and the asset number of which the sms was sent from (AssetID String)
I have attempted copying from the Adafruit_FONA Library, but I must be interfering with the serial or something, when copy the void(setup) into my sketch it shuts down the LCD screen
Sorry for being new to this and asking such a direct question, but any help would be much appreciated
Hello, Have you been able to use hardwareSerial with a GSMshield on Mega?
