When i upload my code to them five work perfectly.
three of them show a statement which is placed in a different progmem space.
During the boot i print logging to the Serialport and the LCD screen these logging which are also stored in program memory contains pretty long strings
2 of them show the same message. the other a different one.
all three show only a part of the different line.
i uploaded the other 5 again to be sure it wasn't my fault due to an error in my code but these keep working as expected.
when i upload an older smaller version of the code. with less progmem variabels i do not have the issue.
As far as i can see the mega's looks the same. i verified the numbers on the chips.
is there an option to show, download or detect the bootloader versions.
because i think the difference is in there.
or someone has a better idea where to find the issue.
I have 8 devices all for different customers. they should be all the same.
and all have the same program.
so i don't understand what you mean with are the connected to the correct port
Yes i did. I verified all the settings and only the clock and lockbyte were different.
I changed the lockbyte of the not working one's but without any luck
when i upload a new bootloader with the nick gammon bootloader. and verify it it looks oke.
when i upload my program the bootloader verify tool notice about 3000 errors.
is that because i write a lot of progmemory or because a program is loaded.
I finally found it.
It was a realy stuppid misstake.
I read in my code the language value from the eeprom.
But because this where new arduinos the value was default so not 0 1 or 2
because i didn't check the value i read the code requested a complete wrong progmem value.
