Help with LED Lamp concept.
Hi all looking for a little (lot) of help with an Idea I have for an LED lamp. It consist of 6 RGB LED’s mounted in a circle in acrylic running on a atTiny85.
The LED’s will cycle though all the colors. I have made a proof of concept and it works fine on the Arduino. I know it is not wired right and that is what I need help with. Right now on the Arduino I have all the Red’s going to pin 3, all the Green’s going to pin 5 and all the Blues going to pin 6. At this time I am not using resistors.
The Forward current on all three colors is 20mA. The Forward voltage on the Red is 2.0 and on both the Green and Blue are 3.0.
I am not sure how much power I will need to drive all 6 RGB’s and the atTiny85.
I know this is asking a lot, but as I am still learning and I learn best by seeing/doing I was hoping maybe one of you pros would like to take me under your wing so to say and walk me though how to wire this. I know how to figure out what size resistors to use, that is once I know what my supply voltage is going to be. But I am thinking I am going to need transistors and maybe a Voltage Regulator. That is where I get lost.
Attached is the code I am using. I got the code off the Net.
Thank you all in advanced for any help.
-Keith
 RGB LED - Automatic Smooth Color Cycling
 Marco Colli
 April 2012
 Uses the properties of the RGB Colour Cube
 The RGB colour space can be viewed as a cube of colour. If we assume a cube of dimension 1, then the
 coordinates of the vertices for the cubve will range from (0,0,0) to (1,1,1) (all black to all white).
 The transitions between each vertex will be a smooth colour flow and we can exploit this by using the
 path coordinates as the LED transition effect.
// Output pins for PWM
#define  R_PIN  3  // Red LED
#define  G_PIN  5  // Green LED
#define  B_PIN  6  // Blue LED
// Constants for readability are better than magic numbers
// Used to adjust the limits for the LED, especially if it has a lower ON threshold
#define  MIN_RGB_VALUE  10   // no smaller than 0.
#define  MAX_RGB_VALUE  255  // no bigger than 255.
// Slowing things down we need ...
#define  TRANSITION_DELAY  70   // in milliseconds, between individual light changes
#define  WAIT_DELAY        500 // in milliseconds, at the end of each traverse
// Total traversal time is ((MAX_RGB_VALUE - MIN_RGB_VALUE) * TRANSITION_DELAY) + WAIT_DELAY
// eg, ((255-0)*70)+500 = 18350ms = 18.35s
// Structure to contain a 3D coordinate
typedef struct
  byte  x, y, z;
} coord;
static coord  v; // the current rgb coordinates (colour) being displayed
 Vertices of a cube
    C+----------+G
  B+---------+F |
   | |       |  |    y
   |D+-------|--+H   ^  7 z
  A+---------+E      +--->x
const coord vertex[] =
 //x  y  z      name
  {0, 0, 0}, // A or 0
  {0, 1, 0}, // B or 1
  {0, 1, 1}, // C or 2
  {0, 0, 1}, // D or 3
  {1, 0, 0}, // E or 4
  {1, 1, 0}, // F or 5
  {1, 1, 1}, // G or 6
  {1, 0, 1}  // H or 7
 A list of vertex numbers encoded 2 per byte.
 Hex digits are used as vertices 0-7 fit nicely (3 bits 000-111) and have the same visual
 representation as decimal, so bytes 0x12, 0x34 ... should be interpreted as vertex 1 to
 v2 to v3 to v4 (ie, one continuous path B to C to D to E).
const byte path[] =
  0x01, 0x23, 0x76, 0x54, 0x03, 0x21, 0x56, 0x74,  // trace the edges
  0x13, 0x64, 0x16, 0x02, 0x75, 0x24, 0x35, 0x17, 0x25, 0x70,  // do the diagonals
#define  MAX_PATH_SIZE  (sizeof(path)/sizeof(path[0]))  // size of the array
  pinMode(R_PIN, OUTPUT);   // sets the pins as output
  pinMode(G_PIN, OUTPUT);
  pinMode(B_PIN, OUTPUT);
void traverse(int dx, int dy, int dz)
// Move along the colour line from where we are to the next vertex of the cube.
// The transition is achieved by applying the 'delta' value to the coordinate.
// By definition all the coordinates will complete the transition at the same
// time as we only have one loop index.
  if ((dx == 0) && (dy == 0) && (dz == 0))   // no point looping if we are staying in the same spot!
    return;
  for (int i = 0; i < MAX_RGB_VALUE-MIN_RGB_VALUE; i++, v.x += dx, v.y += dy, v.z += dz)
    // set the colour in the LED
    analogWrite(R_PIN, v.x);
    analogWrite(G_PIN, v.y);
    analogWrite(B_PIN, v.z);
    delay(TRANSITION_DELAY);  // wait fot the transition delay
  delay(WAIT_DELAY);          // give it an extra rest at the end of the traverse
  int    v1, v2=0;    // the new vertex and the previous one
  // initialise the place we start from as the first vertex in the array
  v.x = (vertex[v2].x ? MAX_RGB_VALUE : MIN_RGB_VALUE);
  v.y = (vertex[v2].y ? MAX_RGB_VALUE : MIN_RGB_VALUE);
  v.z = (vertex[v2].z ? MAX_RGB_VALUE : MIN_RGB_VALUE);
  // Now just loop through the path, traversing from one point to the next
  for (int i = 0; i < 2*MAX_PATH_SIZE; i++)
    // !! loop index is double what the path index is as it is a nybble index !!
    v1 = v2;
    if (i&1)  // odd number is the second element and ...
      v2 = path[i>>1] & 0xf;  // ... the bottom nybble (index /2) or ...
    else      // ... even number is the first element and ...
      v2 = path[i>>1] >> 4;  // ... the top nybble
    traverse(vertex[v2].x-vertex[v1].x,
             vertex[v2].y-vertex[v1].y,
             vertex[v2].z-vertex[v1].z);
kculm:
Don't do it. Not even for testing. Put something in there, anything.
Is the effort of adding a resistor to a circuit worth more than your Arduino?
kculm:
The LEDs need 6 x 3 x 20mA = 360mA
A TIny85 needs about 15mA max, less in reality.
Call it 400mA total - perfect for a USB phone charger (or whatever).
kculm:
Transistors? Yes.
Voltage regulator? Probably not. 5V supplies are common household items in 2013.
fungus:
Noted... Nood Mistake :~
fungus:
That one I am lost on a little. One of the Tutorials I was reading said. If you are using 3, 3.0 Volt LEDs that you would need a 9 volt supply. and if you wanted to use 4 leds you would need a 12 volt supply. What did I not get out of that tutorial.
Also Thansk for the help..
kculm:
That's if you put them in series.
If you put them in parallel you only need enough volts for one LED.
fungus:
Just to make sure I understand the differences.
Series is + to - to + to - and so on.
and
Parallel is + to + to + and - to - to - and so on.
Using the Tool at http://led.linear1.org/led.wiz
it has me using 3, 56 ohms resistors for the red. one resistor for every two LEDS. but it places them on the cathode. I am using common cathode LEDS so is it OK to put them On the Anodes?
I am learning a lot thanks
kculm:
Yes.
Sorry to bug once more, But as I said before i am very new to this. i was hoping maybe you could help me out one more time. I have only worked with transistors once and I was fallowing a video.
In my case using RGB common cathodes do I put the pin out of the Arduino to the Base, 5v to the collector and the LED Anode to the Emitter. Or and I way off.
kculm:
Yes.
Beware though, with the transistor up near the 5V line it will only work if you use a PNP transistor, not an NPN.
fungus:
Yes.
Darn, I spent all day reading up On NPN because I have a bunch. If you don't mind can I ask you a few more questions,
First, Do i have to use Transistors? When I hook it up to My Arduino (with the right resistors) it works like a charm. But when i put it on a Bread Board with a atTiny85 and my DC power supply set to 5v. it works. Not a well, the transition are not as smooth. Is that because of the lack of transistors or is it the at85 .
And lastly. will I need a resistor on the base pin of the PNP if so can you recommend the size.
Once more Thank you for all your help. I would like to repay you some how.
Just wondering what pin definitions you use in place of these on the ATTiny85 version?
As there is no D6 on that uC I'm hoping your ATTiny85 version was using 0, 1 and 4 (physical legs 5,6 & 3) which have hardware PWM support for that analogWrite() later in the sketch.
Cheers ! Geoff
strykeroz:
Cheers ! Geoff
Sorry I posted the sketch for the Arduino.
On the at85 I use 3,Red 0,Green 1,Blue.
kculm:
Shuffle that red over to D4 and I think you'll have a better result. The tiny core doesn't give you hardware PWM control on D3 so the effect of analogWrite() will be a harsh cut-over from OFF to ON.
As identified above, you will still need to drive them using a transistor of some sort as (from page 166 of the ATTiny85 datasheet) the maximum power for any one pin is only 40mA so rather than sourcing the LED power from a pin you'll want to control it from a pin, and have the LEDs draw their power directly from a source that's attenuated by that transistor-PWM combination.
Cheers ! Geoff
kculm:
Common-cathode LEDs cause these pains.
It's basically the same though, except the output will be inverted (pin LOW=LED on).
kculm:
The chip's I/O pins start to burn up at 40mA. There's no way you can drive six LEDs from one pin without damaging the chip (the effect you see is probably the chip fighting for its life).
kculm:
Yes, and for the same reason: You have to keep the current coming out of the chip below 40mA.
330 ohms is a good general-purpose value.
can someone take a look at this before I burn something up.
Thanks
strykeroz:
kculm:
Cheers ! Geoff
Thanks Geoff, But I have a question. The diagram http://www.akafugu.jp/images/microcontroller-reference-sheet.png it show PIN 3 as PWM. am I missing something as usual
thanks
all most there.
I have one last issue, When I run it with out transistors on the Arduino it works smooth. But when I use 3, PNP transistors it works fine up until the Green to Blue transition. It almost dims out completely then flicker to blue.
You can see what I am talking about here.- YouTube The first 45 sec our so is with out Transistors. After a few sec of blackness it with transistors.
Sorry for the poor video
kculm:
strykeroz:
kculm:
Cheers ! Geoff
thanks
it is. It's just not usable as one in the Arduino IDE. use 4 and you'll be fine.
kculm:
There's a hardware limitation: Pin 3 can only output the inverse of pin 4, pin 4 is the 'true' signal.
fungus:
kculm:
While that's strictly true for the datasheet, in reply #38 of this thread on ATTiny85 and PWM Coding Badly explained that the inverted PWM output can't be used by the Arduino cores for ATTiny. My own testing confirms this gotcha - that D3 is not able to use hardware PWM with the arduino-tiny core. Software PWM like the tone() function works fine on all 5 of the standard ATTiny85 IO pins though, so there's an easy way around this limitation if you must use that leg.
Cheers ! Geoff
